Hood Struts
Old Nov 23, 2015 | 08:29 AM
DaveC's Avatar
Default Hood Struts
My hood struts have gone kaput. They don't look too expnesive. Are they easy to replace or is some special tool, hardware needed?
Dave
Old Nov 23, 2015 | 11:09 AM
Snide72's Avatar
Default Easy Fix
Check out: 2000-2014 Jaguar XKR Hood Strut - Rhino Pac 6585 - - PartsGeek.com. They're about $30 and easy to install.
Old Nov 24, 2015 | 08:13 AM
DaveC's Avatar
Thanks, ordered and on the way. Hopfully, it is as easy as you say. The shop manual is pretty vague.
Old Nov 24, 2015 | 08:49 AM
Snide72's Avatar
Default 2 Guys Work Best
If you have a friend help you, it makes it easier and safer. If both struts need to be replaced because the 2 together won't hold the hood up, have someone hold the hood up while take off the first strut and install its replacement. Ditto on the second strut. And, when you close the hood, always hold it in the middle or you'll often get only one side to latch but not the other side.
Old Dec 3, 2015 | 12:10 AM
DaveC's Avatar
Really an easy job. Took all of 5 minutes. What a difference. You lift the hood up about a foot and the struts take over. It almost looks electric. It is a little harder to close now.
Old Dec 3, 2015 | 06:25 AM
Snide72's Avatar
Default Super!
Glad to hear it went well for you. Another happy Jag owner!
