How do I remove driver seat?
Old May 12, 2013 | 08:48 AM
pabanker's Avatar
Default How do I remove driver seat?
I dropped a very important key that is now stuck somewhere between the right side of the driver seat and the center tunnel, deep where I can't see it. I can't get at it from the below the front or back of the seat, I'll have to remove the seat. Can anyone tell me the tools I need, and give me a general idea of where/what I need to unscrew or unfasten? Thanks in advance!
Old May 12, 2013 | 09:23 AM
DGL's Avatar
DGL
The seats are bolted to the floor on two rails. Each rail has a front and rear bolt. You need to move the seat back to expose the front bolts and undo them. Then move the seats forward to release the back bolts. The wire harnesses attach under the seat. To retrieve your key you shouldn't need to remove the seat. just lift t up so you can feel around to find the key. No need to release the wire harnesses. Once you find your key reinstall the bolts. I looked for the section in the workshop manual to find seat section but could not quickly locate it. I'll try again later. However, if you look at the bolts mentioned above you should have no problem figuring out the proper tools required. Good luck.
Old May 12, 2013 | 09:31 AM
DGL's Avatar
DGL
Default Diagram:
Diagram for seat removal:
Old May 12, 2013 | 09:39 AM
DGL's Avatar
DGL
You may want to try a magnet attached to stick to try to retrieve it.
Old May 13, 2013 | 06:14 PM
pabanker's Avatar
Thanks guys, success. The only hard part was I had to go to an auto parts shop to get the right torx sockets. Why don't the car companies just use the standard hex nuts and bolts?
Old May 13, 2013 | 06:39 PM
axr6's Avatar
DGL - thanks for the effort you made to help a member. This is what makes or breaks a forum, members like you.
Albert
dsnyder586
Dec 29, 2024 07:39 PM
Jpav27
Jul 31, 2022 06:43 AM
GordoCatCar
Jan 2, 2017 01:10 PM
Dallas XK8
Sep 3, 2015 12:17 PM
dcvickers
Sep 2, 2015 06:14 PM
