How to Remove the Chrome Window Strip and Rubber Molding?
Old Sep 1, 2020 | 02:04 PM
silvertonesx24's Avatar
Default How to Remove the Chrome Window Strip and Rubber Molding?
A leaky hydraulic cylinder has ruined the weather stripping on my 07 XKR. Any idea how this is removed so I can replace it?
Old Sep 1, 2020 | 06:58 PM
jahummer's Avatar
It is referred to as belt moulding and is friction fitted so it just pulls straight off.
Old Sep 2, 2020 | 08:41 AM
barnsie's Avatar
As jahummer says, it pulls off. I had to replace mine as it was corroded. Start at the handle-end of the door, with the window down, and use your thumbs to push up on the moulding. If it won't budge, carefully use a plastic trim-remover tool to get in between the trim and the door and lever it a little. Once you have it eased away from the door, it will gradually push off as you work down the length of it. The trim piece sits on a small 'ledge' on top of the door. Mine was held on with four metal retaining clips but these had started to corrode and since metal (steel) to aluminium is not a great idea, I removed these and threw them away. The trim fits tightly enough onto the door 'ledge' that they are not needed, and I wanted to avoid future corrosion issues. I did this about a year ago and the trim pieces on both sides are still perfectly installed.
I did have a thread on it, or part of someone else's thread, but Search isn't showing it.
Old Sep 2, 2020 | 08:45 AM
barnsie's Avatar
Found it!
https://www.jaguarforums.com/forum/x...lation-223782/
Old Sep 2, 2020 | 09:07 AM
Thanks! That thread is perfect. Now to find the weather strip without paying $$$$$, I might call junkyards with XKs and see if they'll send me one.
Old Sep 2, 2020 | 09:33 AM
jahummer's Avatar
Might you have it refinished?
Old Sep 2, 2020 | 09:36 AM
My aluminum is perfectly fine, it's the rubber that is wiggly and warped and looks like trash. I'm not aware of any process that could fix that outside of replacement
I like my Titan lifts but this leaky cylinder from the factory is causing all kinds of problems.
Old Sep 2, 2020 | 01:04 PM
kj07xk's Avatar
Ok, I was wondering how hydraulic fluid got there!
Old Sep 2, 2020 | 02:23 PM
It ruined the window strips on both of my Jaguars.
My other lift is great though.
Slownot
Apr 19, 2020 06:38 AM
XFowner
Oct 6, 2019 12:07 PM
User 070620
Jan 11, 2014 02:05 AM
Darel
Aug 13, 2012 05:05 AM
