How to remove coolant expansion tank 2011 XK
Old Jul 8, 2023 | 11:21 PM
David's XKR's Avatar
Default How to remove coolant expansion tank 2011 XK
It should be easy. But it's not. It appears to be attached from the bottom. Anyone know what to do?
Old Jul 9, 2023 | 08:29 AM
jahummer's Avatar
It slides out from the bottom, see the right side of this pic
Old Jul 11, 2023 | 10:10 PM
Based on the picture, it looks like it should slide out toward the fender. I have it drained and the two hoses released. But I can't get it to slide out. It seems looser the opposite way but there's a big bar there.
Old Jul 12, 2023 | 04:34 AM
427MikeB's Avatar
The workshop manual says to remove the cross brace that you refer to. To do that you need to remove the plastic windscreen cowl, which means removing the wiper arms. The expansion tank then slides towards the engine.
Old Jul 12, 2023 | 08:13 PM
jahummer's Avatar
Only the brace needs to be loosened enough to slide the tank out easily, I've done mine. Nothing else needs to be removed.
weltidave
Mar 5, 2022 09:15 AM
cityboy
Oct 20, 2021 09:21 AM
Tracee
May 29, 2019 10:22 AM
jaguarcraver
Jul 30, 2012 10:19 AM
scubayachts
Oct 20, 2010 12:18 PM
