How to replace rear piston dust cover and seal?
Old Aug 1, 2021 | 08:25 PM
BlueXKR-S's Avatar
Default How to replace rear piston dust cover and seal?
I installed new rear brake pads today and I noticed that a dust cover round a piston has a small hole in it, both side. Is it possible to replace it without taking the caliper apart and rebuilding it? In the manual it's called "piston dust cover and seal".
I am going to stop by my local dealer to see if I they sell it. I see Ate #11.8102.4410.2 stamp on it, but online search does not show anything.
Has anyone replaced it without taking the caliper apart?
Old Aug 1, 2021 | 10:20 PM
jahummer's Avatar
It likely Jaguar would sell this separately. You may find it by searching by the caliper and service parts.
Old Aug 20, 2021 | 12:06 PM
BlueXKR-S's Avatar
Took it to the dealer to get done. It turned out the boot can be replaced without taking the caliper apart and opening the system. The boot does to act a seal between the piston and caliper. Slide the old boot off and put the new one back on. The only complication is that a special tool is needed to "tap" the boot back in place over the caliper. I've seen some threads here though describing how to make it out pf PCV pipes, big washer so to speak.
romroc
Mar 28, 2021 09:33 AM
Rhys
Dec 26, 2020 05:42 PM
Mark McDonald
Sep 2, 2020 08:02 AM
Doug Dooren
Aug 30, 2015 01:40 PM
thuffner3
Feb 2, 2012 05:53 AM
