I got my wheel spacers today!!!
Old Jul 16, 2019 | 07:27 PM
Don-T's Avatar
Talking
But then we could send you all our stuff for you to cut down!
Old Jul 17, 2019 | 02:04 AM
Sovejag13190's Avatar
Originally Posted by Reverend Sam
The spacers don't move in relation to the wheel. No bearings are required. They basically just increase the offset in the wheel.
Sorry but i want say these spacer don't broke wheel bearing at the long time.
Old Jul 17, 2019 | 10:22 AM
Cee Jay's Avatar
True, in most cases. However, the XKs have such a large offset that even with a spacer the bearing area is still within the barrel of the wheel.
On other vehicles a spacer CAN affect in a much more dramatic fashion and ruin bearings. Those vehicles usually have a negative offset PLUS spacers and put therefore put load on the bearings INSIDE the barrel of the wheel. Not a good situation.
"C'est vrai, dans la plupart des cas. Cependant, les XK ont un décalage si important que même avec une entretoise, la zone de roulement reste dans le corps de la roue.Sur d'autres véhicules, une entretoise PEUT affecter de manière beaucoup plus dramatique et ruiner les roulements. Ces véhicules ont généralement des entretoises offset plus négatives et mettent donc une charge sur les roulements à l’intérieur du corps de la roue. Pas une bonne situation."
Old Jul 17, 2019 | 10:44 AM
Thank's for response. The must is 20 mm front and 15mm rear ?
it's not necessary make wheel alignment ?
I'm interesting by this kit -> Wheel spacers
What do you think about this kit ? It's good ?
Old Jul 17, 2019 | 11:53 AM
Ranchero50's Avatar
One nice thing is some factory wheels have pockets between the lugs where the stud will sit
Old Oct 19, 2019 | 01:24 PM
Reverend Sam's Avatar
So... the 20mm spacers on the rear turned out to be slightly too wide. Every once in a while I would hit a particularly bad dip and one of the rear tires would rub the fender liner. I put up with it for a couple of months, but I finally realized I needed to swap out the 20mm spacers for 15mm spacers, which I did last weekend.
If anyone wants my 20mm spacers, which are good for the front wheels, just send me a PM. I'm not giving them away, but I'll sell them cheap.
Old Oct 19, 2019 | 02:06 PM
TexasTraveler's Avatar
well since I put on my GT 5 spokes I didn’t need my 15mm spacers for the rears, so I have a set that I would sell... So long story short if someone wanted Sam’s 20’s and my 15’s they could have a full set for their ride....
Old Oct 19, 2019 | 10:15 PM
  #28
gkubrak's Avatar
PM sent to both.
burmaz
Jul 1, 2013 06:59 PM
Sentinelist
Feb 20, 2013 10:29 AM
YaoNYC
Nov 3, 2008 09:22 PM
sempaipaul
Jan 28, 2007 01:47 AM
Apr 30, 2006 10:40 AM
