Idle adWeiss needed
Old Apr 24, 2023 | 05:53 AM
JagV8's Avatar
The fuel trims should settle very soon so just look at them: hot engine, parked, at idle.
Old May 4, 2023 | 05:32 PM
McJag222's Avatar
Just got back from the local shop - he setup the OBD11 diagnostic - cleared all the codes and fired up the car - misfires on cylinders 6 and 8 - I'm guessing the ignition coils are the problem:
Old May 5, 2023 | 02:54 AM
JagV8's Avatar
If easy, swap coil positions (but not 6 with 7!) and see if fault moves.
A cheap OBD tool is all you need for this stuff e.g. elm327
Old May 5, 2023 | 07:41 PM
McJag222's Avatar
For some reason the Car Scanner Pro app (recommended by Jahummer) that I recently bought was not showing any misfire or related codes. Plus the guy did a more comprehensive check with detailed explanations.
Old May 6, 2023 | 05:52 PM
McJag222's Avatar
So does anybody know what OBD2 app will read misfiring cylinders? - my Dash Command says "Misfiring monitoring" green. I don't see where the Car Scanner Pro reads misfires.
Old May 6, 2023 | 11:49 PM
Bill400's Avatar
FYI: OBDII Misfire diagnosis explained:
Misfires in OBD II Engines: Detect (underhoodservice.com)
Old May 7, 2023 | 11:25 AM
McJag222's Avatar
Thanks Bill - there is lots of good articles out there. This guy has an interesting three part series of vids when no codes show up. The last of the three is interesting:
I might hookup the SDD to see if the software shows misfires - not sure if it does. The Torque Pro app is said to display misfires - but it's only for Android and no ipad/apple
Old May 8, 2023 | 06:47 AM
  #28
Bill400's Avatar
Great videos!
It appears that the new BAFX will do Iphone:
Old May 9, 2023 | 02:30 PM
clubairth1's Avatar
Community Influencer
SDD will certainly show misfire codes.
Harry Dredge
Nov 2, 2015 12:31 AM
Rotorbug
Jun 4, 2012 11:07 AM
gunnerman
XJ40 ( XJ81 )
Aug 15, 2011 03:33 AM
