inner tie rod torque
Old Sep 8, 2024 | 06:58 PM
unklebuck's Avatar
Default inner tie rod torque
Had a look through the service manual pdf and I cannot find anything about the inner tie rod torque setting to the power steering rack.
I am replacing both inner tie rods and the outer tie rod ends/balljoint
In the manual there is info on the tie rod ends:
Thats all good but I cannot for the life of me find anything about the inner tie rod to the steering rack torque requirements.
Anyone know what it is?
Old Sep 8, 2024 | 07:56 PM
McJag222's Avatar
I don't think the lock nut really needs a torque setting - a good swing on the wrench should be good enough - that's why they didn't give a torque setting.
Old Sep 8, 2024 | 11:40 PM
kj07xk's Avatar
Right. You count the turns to put the tie rod back on, equaling the removal, and that should bring the new one into the proper position next to the lock nut. The tie rod can’t unscrew once the ball joint end is attached, so the locknut doesn’t need to be ‘cranked’ up to the tie rod end.
Old Sep 9, 2024 | 10:45 AM
guy's Avatar
guy
But… in my workshop manual, all suspension and steering locking nuts are torqued to 40 lb ft.
Cheers!
Devin Roland
Jun 28, 2017 07:13 PM
Sean W
Aug 31, 2015 04:11 PM
wesmc
Apr 13, 2015 06:49 PM
mhamilton
Dec 25, 2013 12:33 PM
zez172
Nov 6, 2012 08:30 PM
