Interior drivers door handle fault?
Old Jan 9, 2025 | 03:01 AM
alanroberts50's Avatar
Default Interior drivers door handle fault?
When I start driving the passenger door locks as it’s supposed to but the driver’s door handle doesn’t. If I push it into the lock position it easily locks. Is this a security setting or is the locking mechanism faulty?
Old Jan 9, 2025 | 04:10 AM
Mjyfly's Avatar
I had exactly that problem. My local specialist changed the locking mechanism, which solved it.
Old Jan 9, 2025 | 12:03 PM
LJRXKR's Avatar
Funnily enough, mine also does that. But I never had someone on the outside to test and see if it indeed was locking the drivers door or if it was being weird. Could be worth a go?
Old Jan 10, 2025 | 11:02 AM
synrgy's Avatar
I had the same problem. I worked the handle to lock- unlock about 10 times and it corrected itself. It was still working fine when I sold the car 2 years later.
Old Jan 13, 2025 | 07:13 AM
Thanks for the suggestion, I’ve been trying that but so far no change
Jag Bass
Feb 1, 2026 08:33 AM
POD XF
Oct 25, 2024 06:31 PM
FastCat85
Nov 13, 2021 09:16 PM
80sRule
Sep 13, 2020 12:03 PM
Jon89
Apr 5, 2019 01:23 PM
