Intermittent misfire
Old Apr 13, 2024 | 03:19 AM
Carl F's Avatar
Default Intermittent misfire
Hi
I have a 2008 XKR. Every no and again I get a misfire under load. Codes P0307, P0307 and P0300.
I've changed plugs and cylinder 6 & 7 coil packs. Seemed ok but then last weekend it happened again with limp mode and had obviously lost 1 or 2 cylinders. Turned off then in again and it cleared, got home and sure enough the same codes appeared.
It's 2 opposite banks so I'm ruling out cat or sensor.
My next thought would be injectors but I'm still thinking electrical.
Any thoughts?
Carl
Old Apr 13, 2024 | 03:44 AM
RichardS's Avatar
I'm thinking possibly a fuel delivery/pressure issue rather than individual injectors but I'm surprised there are no codes for that.
Richard
Old Apr 13, 2024 | 12:55 PM
sony2000's Avatar
First to change should be the pressure regulator sensor in the fuel rail. On occasion it maybe the engine temp sensor, sending the wrong info to the computers.
XKRs run at 72.5 psi or 5.0 bar
Old Apr 14, 2024 | 03:25 AM
xalty's Avatar
look at your misfire counter, 7 and 3 are companions.
i fought this on an xf sc that would only act up around 3k rpm. updated pcm and ton of bg 44k so far so good
Lannyl81
Dec 21, 2022 07:22 AM
jhxj6
Jul 20, 2022 11:49 AM
PYR8_K1NG
Nov 10, 2020 01:51 PM
Rnanc44
Jan 15, 2020 10:37 PM
tiny_jag
Jan 28, 2015 02:53 AM
