iPod
Old Jan 9, 2014 | 12:59 PM
Gmancuso's Avatar
Default iPod
Hi guys,
I have an 09 XKR with an iPod hookup. Problem is it doesn't charge while playing. What do I need to buy so that it will charge.
Thanks,
Gary
Old Jan 9, 2014 | 01:01 PM
Executive's Avatar
If you are using the cable that came with the car, try out the ipod/iphone charger. See if that helps.
If not, you may need a software reflash.
Old Jan 9, 2014 | 03:28 PM
Rw99's Avatar
I had a similar problem with an iPod Nano (circa 2012 model, the square one) and my 2012 XKR-S. I bought a pass-through adapter (i.e. 30-pin to 30-pin) and now it charges as it plays... and I can just leave it connected to the car all the time.
No guarantee it'll work for you, but it's $23:
Amazon.com: CableJive dockStubz+ Charge Converter and 30-pin Pass Through Adapter for iPhone, iPod, and iPad: Electronics Amazon.com: CableJive dockStubz+ Charge Converter and 30-pin Pass Through Adapter for iPhone, iPod, and iPad: Electronics
Good luck...
Rich
Old Jan 9, 2014 | 09:13 PM
Stuart S's Avatar
Gary,
This has been extensively discussed in several prior threads. See my posts ##6 and 10: https://www.jaguarforums.com/forum/xk-xkr-33/portable-audio-interface-ipod-nano-6g-50122/
If you have an older iPod (not one with the new connector), you're in luck and can get it to charge and play simultaneously at a reasonable cost. The least expensive alternative is the Scosche adapter, which is what I've been using for almost year without any problems. Or, you can buy the more expensive new Jaguar connector part # C2P21008 as discussed in the above thread.
If this was helpful, please click Thanks at the bottom right of this post.
Stuart
42Ajd
Dec 30, 2015 09:45 AM
42Ajd
Sep 26, 2015 07:04 PM
42Ajd
Sep 21, 2015 07:37 PM
flyrr100
Sep 18, 2015 06:31 PM
Darrenmb
Sep 9, 2015 09:31 PM
