Jacking up the front end - RESOLVED
So my "search-fu" is terrible and I can't find anything that directly addresses where to put a floor jack under the front end of an 07 XKR. I think the jack stands would go under the side jacking points, but that may be wrong as well. Where's the correct jacking point and where should the jack stand be placed?
Last edited by GGG; Dec 10, 2020 at 03:13 AM. Reason: Add "RESOLVED" to thread title
found this for you, should be relevant, scroll down to the diagram https://www.jaguarforums.com/forum/x...ts-xkr-187308/
jack point should have an indicator on the frame. stands typically go on a pinch weld so this looks right to me. (edit: doesn't really look like a pinch weld in the photos, but it's reinforced something or other, should be easy to spot)
if you were thinking of using a single jack point in the front to then slide two stands under both sides, no, i guess that's not how you do it.
TreVoRTasmin
Mar 10, 2020 11:24 PM
