Jaguar Breakers
Old Apr 21, 2020 | 11:36 AM
pauledddy's Avatar
Default Jaguar Breakers
Hi guys,
Anyone know of any Jaguar breakers in the UK? I'm after a 5.0 SC engine!
Thanks in advanced
Old Apr 21, 2020 | 11:40 AM
Stuart S's Avatar
Google "U.K. auto breakers".
Old Apr 21, 2020 | 11:47 AM
pauledddy's Avatar
That'ss all well and good but i'd like to be recommended a good breakers or individual. Especially when it comes to buying an engine
Old Apr 21, 2020 | 12:38 PM
Stuart S's Avatar
Buying a used engine from a breaker is always a crapshoot even if you have done your due diligence. A recommendation from a member of this Forum is just one piece of that due diligence, but is certainly not the sole reason to rely on to make that purchase because there may be other buyers with negative experiences with that seller. Does the seller offer a written guarantee? What is the seller's return policy? How many miles are on the engine and did the seller run it and have diagnostic data including, but not limited to, oil pressure at idle and at operating speeds and cylinder head compression test values for all cylinders? Make sure that you take notes or record everything the seller tells you about the engine, write it up as a memo to your file, and send a copy to the seller (with receipt confirmation) before you buy it. You are the only one who can protect yourself in case the seller misrepresented that engine.
You can also Google "Review (name of breaker)". Good luck!
Old Apr 21, 2020 | 01:16 PM
mosesbotbol's Avatar
Is the Land Rover version a true swap for the engine?
Old Apr 21, 2020 | 01:17 PM
pauledddy's Avatar
Yes, have to change the belt and remove the fan but other than that it's exactly the same
Old Apr 21, 2020 | 05:22 PM
Cee Jay's Avatar
I'd figure the LR engine would be made with lower compression.
Old Apr 28, 2020 | 11:53 AM
Coley0312's Avatar
Have you tried EuroJag? I purchased a 2.7 Diesel engine from them a few years ago. They seem to have a lot of spares usually.
https://www.eurojag.com/
shaikhzeep
Feb 27, 2020 08:02 PM
paulyling
F-Pace (X761) / C-X17
May 2, 2015 04:31 AM
mycaptainchris
Non-Jaguar Vehicles
Sep 3, 2010 04:59 AM
