Just when I thought it was safe to go back in the ocean!!
Old Oct 21, 2025 | 03:14 PM
HealeyJag's Avatar
Originally Posted by guy
I always meant to. Does that count?
Nonetheless, my garage is always locked. And the cars at the Ferrari museum (Torino) are unlocked
I WAS counting on YOU!
Old Oct 21, 2025 | 03:44 PM
Circumnavigator's Avatar
Originally Posted by HealeyJag
Has anyone confirmed that there is more battery drain by NOT locking your car yet shutting down all accessories vs double locking and having the alarm draining the battery..
I never lock mine in the garage.
Heck most times I leave the key sitting on the car.
My recent experiment, which started at 12.4x
No Ctek, drove 5hrs. Parked in garage, didn’t lock or check voltage.
24hrs sitting, 12.57v (charged during the drive.
Just went out, sitting 48hrs, unlocked and I turn it off without turning off radio, AC or any of that.
12.49v.
Will be driving it maybe 5mi this evening, but will check tomorrow.
If it drops more, I’ll hook up the Ctek.
Old Oct 21, 2025 | 04:27 PM
HealeyJag's Avatar
12.49v.
I thought that leaving key in the car keeps the accesories hot and drains system?
Old Oct 21, 2025 | 04:45 PM
Sean W's Avatar
Does this help?
File Type: pdf
Old Oct 21, 2025 | 04:57 PM
HealeyJag's Avatar
Default Nope
Originally Posted by Sean W
Does this help?
Looking fir definitive proof that the alarm doesn't drain more than not locking car..
Circumnavigator seems to have found no effects of leaving keys in car AND not locking?
Old Oct 21, 2025 | 06:22 PM
I didn’t say no effects. It dropped from 12.57v to 12.49v in the second 24hrs of sitting.
Top down. Key fob sitting on the flat surface behind the psgr door.
Opened the trunk twice, but with LEDs in there doubt it drew much.
I am actually shocked having seen many threads about the alarm system, nobody measured the standard current draw for the alarm when operating as designed with no short or issues.
I’ll now be spending the next 10m reading the doc Sean shared, but on page 1 I found this comical:
Close/latch all doors. But measure at battery. Which requires the trunk to be open, especially on a convertible.
Yes I realize it is directed at mechanics who have SDD.
But for a multimeter, this is impossible:
Old Oct 21, 2025 | 06:40 PM
HealeyJag's Avatar
Default Brain
Love your engineer brain!!!
Old Oct 21, 2025 | 06:54 PM
  #28
guy's Avatar
guy
You’re not alone… but that is inaccurate.
Old Oct 21, 2025 | 06:57 PM
HealeyJag's Avatar
Ok...back to original question..
Does not activating and not locking the car actually cause more battery drain?
Old Oct 21, 2025 | 07:24 PM
  #30
guy's Avatar
guy
Does this help?
Damn… he beat me to it ;-)
Cheers @Sean W
Old Oct 21, 2025 | 07:30 PM
  #31
guy's Avatar
guy
:-) have a read of the workshop manual. The car will automatically shut down after a period of time. It can be as long as 20 minutes.
short answer: no.
incidentally, you are not alone and you’re thinking. In the beginning days, there was a lot of conversation about the electronics.
Old Oct 21, 2025 | 11:34 PM
  #32
kj07xk's Avatar
Ok, so it’s not telling you how to fool the car into thinking the trunk/boot is closed and latched, or how to run longer leads to the meter outside the trunk/boot, and close the lid on them? Easy enough to do either one, not rocket science.
Old Oct 22, 2025 | 09:29 AM
  #33
wymjym's Avatar
WOW!
of course the alarm draws current, if it didn't it would not work.
So...
wj
Old Oct 22, 2025 | 10:35 AM
  #34
Sean W's Avatar
yep, also, open the door and physically close the latch while leaving it open. then press the lock button on the FOB. you've tricked you car into thinking the door is closed. Though I've never done this on the boot, I do it all the time when cleaning my interior. Easiest way to see that it's working after to physically close the latch with a flathead screwdriver. When you press the lock on your FOB, the dome light goes off immediately. That or just get longer leads as @kj07xk noted.
Old Oct 22, 2025 | 11:30 AM
  #35
I was just nit-picking.
I’ve done it for the boot while I was hard wiring the Ctek and messing about.
Doing the doors just never crossed my mind.
Will test on t after my 3 days sitting battery measurement.
Old Oct 22, 2025 | 07:20 PM
  #36
HealeyJag's Avatar
Surprised you haven't done a test after double locking , to see what difference it makes..
Old Oct 22, 2025 | 07:41 PM
  #37
Now you’re tempting me.
But I’ve already gotten the Ctek involved.
Old Oct 22, 2025 | 08:18 PM
  #38
HealeyJag's Avatar
Next experiment!!
Old Oct 22, 2025 | 08:32 PM
  #39
Stuart S's Avatar
US members who "double lock" their X150 will get a "beep beep" from the sounder. That double beep is an error message that means your car is not double locked. That's because double locking is not available on US market cars.
Double locking is not available on USA market vehicles because NHTSA deemed it to be unsafe. Double locking is popular in Europe because it makes cars more difficult to steal. However, because the doors cannot be opened from the inside when double-locked, a small child or other passenger can be trapped inside and die from extreme heat.
When you double-lock your car, the beep-beep is an error message to tell you that your car is not double-locked. Visual confirmation that your car is, in fact, locked is that your side mirrors automatically folded in, unless you disabled that feature or your car is not equipped with that feature.
For more information:
See: NHTSA January 2009 Double Locking
Old Oct 23, 2025 | 02:21 PM
  #40
HealeyJag's Avatar
I DO NOT get a double beep!
It just beeps once..
