Kasuga rims - tire sizes
Old Apr 30, 2012 | 12:26 PM
TTC's Avatar
TTC
Default Kasuga rims - tire sizes
Hi everyone,
I've been looking around for some 20" rims for my xk and I've pretty much settled on going for Kasuga's. Now I've got a lead on a really great set which the seller claims will fit on the xk and xj, but the tires fitted are listed as being 245/40/20 and 275/35/20. This seems correct for the xj but everywhere else I've looked seems to suggest that for the xk 255/35/20 And 285/30/20's should be fitted. Any thoughts?
TIA,
Tony
Old Apr 30, 2012 | 12:56 PM
aahmichael's Avatar
Originally Posted by TTC
Hi everyone,
TIA,
Tony
I'm also going to put Kasugas on my XK. My dealer told me that the reason the two cars use different size tires on the same wheel is because the XJ sits higher off the ground than the XK does.
Old Apr 30, 2012 | 05:30 PM
axr6's Avatar
Hi everyone,
TIA,
Tony
The 245x40 = 98mm sidewall height
The 255x35 = 89.25mm
The 275x35 = 96.25mm
The 285x30 = 85.5 mm
So, the 255 and 285 combination results in nearly 18-20 mm difference in the tire/wheel diameter which means that with this set the car would ride about 9-10 mm lower. It is also likely the size that your speedometer is calibrated for.
Albert
MrWest
Dec 1, 2015 09:18 PM
lickahotskillet
Oct 18, 2015 09:51 AM
Gerard Radimaker
Sep 13, 2015 10:33 AM
lickahotskillet
Sep 11, 2015 07:54 PM
