Latest water pump part number
Old Feb 14, 2019 | 04:38 PM
  #41
bocatrip's Avatar
Originally Posted by 8bit
Have you tried changing the expansion tank cap?
Yup. Been there, done that. Thanks anyway.
Old Jul 2, 2019 | 04:12 PM
  #42
BlueXKR-S's Avatar
Hi
Can you share the part numbers for the new C, Y, and plastic bleeder parts?
Originally Posted by riverman
Having just completed a coolant pump change in my 2010 XKR, the latest revision I found was AJ813909. After a couple hours research looking for the hard (brittle) tube (B in graphic) and the little Y shaped part number (A in graphic) connecting the pump bypass and the throttle body to the heater return, I realized the design had been changed to a simpler and more reliable configuration. The Y part is no longer available, nor is the hard tube. They are replaced by a new design that has a thick rubber tube coming off the large coolant tube (C in graphic) thermostat to upper manifold. As my car is a daily driver who has put about 60k of the 120k miles on my XKR, I try to minimize unecessary downtime. As I do my almost all of my own mechanical work, I would definitely recommend at a minimum changing those parts (for about $100 US) and save yourself the extra hours of labor that will be needed when they deteriorate from the inside out simply due to age. The new design requires replacement of the large coolant tube and the Y part, but eliminates the brittle plastic tube, and you get a new plastic bleeder connection to plug into the coolant pump, which is another common failure point that will cause you to have to go to the new design.
OLD DESIGN - 5.0 S/C
NEW DESIGN - 5.0 S/C (you can just see the new grey colored "Y" part at the top of the picture.)
Old Jul 2, 2019 | 09:54 PM
  #43
ralphwg's Avatar
I'm not sure if the following part numbers are what you are looking for. My water pump was replaced last week including the following hoses/pipes.
Water pump AJ813909
TUBE C2Z18658
PIPE-OUTLET AJ813865
TUBE AJ813917
HOSE C2P13304
Old Jul 6, 2019 | 09:45 PM
  #44
BlueXKR-S's Avatar
Thanks. Do you know why they replaced the last two parts? Were they leaking?
Old Jul 7, 2019 | 01:05 AM
  #45
riverman's Avatar
I bought Land Rover parts as they were cheaper; Several sites will provide cross reference numbers to Jaguar part numbers... The bleeder is included now on the large coolant down tube to the thermostat (P/N: RV-LR049989). The "Y" or arrow A in graphic is Throttle Body Heater hose (P/N: RV-LR045238) and the small outlet on it is now sealed and not used since the bleeder tube now connects to the down tube.
Old Jul 7, 2019 | 05:20 PM
  #46
ralphwg's Avatar
C2P13304 was cracked and leaking. From the description I believe that this hose is part of the oil cooling system.
Old Jul 7, 2019 | 11:10 PM
  #47
tberg's Avatar
Hey Ralph,
I had the same part replaced as well as my oil cooler which was also leaking. Fortunately, we took the old oil cooler off my original engine so I wasn't forced to buy a new one. How idoes Friday for lunch look?
Old Jul 8, 2019 | 07:42 PM
  #48
ralphwg's Avatar
Hey Ted - Fridays are not good for me. I usually play Bridge or do a family thing with one of the Grand kids. Any other day this week is good. Ralph
Old Oct 28, 2019 | 05:04 PM
  #49
jfwilson76's Avatar
Would you happen to know what the Jaguar Part Number is for this hose on the supercharged versions? Thanks.
Paulc732
Jan 20, 2024 09:45 PM
Bigg Will
Nov 28, 2018 09:29 AM
sidescrollin
Jan 9, 2018 11:26 AM
supra-raleigh
XJ40 ( XJ81 )
Sep 23, 2014 10:30 AM
