Lime overflowing coolant when opening the expansion tank
Old Dec 13, 2020 | 04:33 AM
Xk646's Avatar
Default Lime overflowing coolant when opening the expansion tank
Hello, following a walk in I had a micro leak at the level of the expansion tank hose I opened the tank cap and it overflowed a lot and this morning my tank was empty I specify with the engine hot so in normal pressure that it overflows since the maximum level is just below the cap with the expansion of the liquid?
Old Dec 13, 2020 | 06:13 AM
80sRule's Avatar
Ok, you open a pressurized coolant system and you are BEGGING to get burned. It is under 15-20psi and will come out like raging lava to burn you. I've had a tank explode due to a hot plate plastic weld failing and have the burns to show.
Basically, the coolant at any temp should be between those two lines. Top it off, then properly bleed it (the bleed screw on tank makes it easier). You introduced a lot of air into the system.
Old Dec 13, 2020 | 09:17 AM
Sean W's Avatar
For future reference, these engines can take a few hours to cool down depending on how hard they're driven and the ambient temperature. Before you ever open up the cooling system, touch the hottest part of the engine and if you can keep your hand on it, fine. Better still, use and infrared thermometer on the hottest part of the engine. Best - wait till next morning.
Old Dec 13, 2020 | 09:22 AM
Xk646's Avatar
Ok
Old Dec 14, 2020 | 05:29 AM
Coolant level is always checked COLD and you will see the MAX and MIN level marks are well below the base of the filler neck:
Topping up should be with a 50/50 mixture coolant/water. My preference is to use de-ionised or distilled water. Coolant specification is WSS M97B44. This is normally coloured orange and called "Extended Life Coolant".
The X150 doesn't normally use or lose coolant so you are right to investigate any loss. Use a Pressure Test Kit to check for sources of leaks.
Old Dec 14, 2020 | 07:34 AM
SinF's Avatar
This is important point to consider moving forward. Air bubbles in the cooling system drastically reduce cooling effectiveness, to the point that the car may start overheating.
Also, if you are not going to take it to the shop, ask them to pressure test the system.
Old Dec 14, 2020 | 04:29 PM
MarkyUK's Avatar
It seems a common failure, well at least my 2014 had it and the hose was brittle/cracked & required a new hose assembly, not that expensive IIRC £40
I'd dig out the receipt for mine but the part no may be different on your 4.2.
PS: Didn't understand the 'lime' in your thread title??
Old Dec 15, 2020 | 09:06 AM
caspia's Avatar
Many thanks. I will check this.
Xk646
Dec 13, 2020 10:59 AM
jazzwineman
Jan 20, 2015 03:02 AM
major90
Feb 9, 2014 02:56 PM
smitty5534
Aug 20, 2011 03:52 AM
cdmarano@gmail.com
Jul 27, 2008 08:54 PM
