Lower RPM misfire with no cell light. Ignition coils?
Old Oct 30, 2019 | 04:21 PM
AlexJag's Avatar
Sponsor
Default Lower RPM misfire with no cell light. Ignition coils?
So I've had this for years on my car . It's a slight misfire between 800 and 1800 RPMs. There are no codes reported, but I know it's there. It seems that the problem gotten worse when I installed spark plugs with lower Gap since I need that pushing more power.
the biggest suspect is ignition coils, car has nearly 94,000 miles and I know they are still original. Anyone ever replace the ignition coils to resolve this issue and what brand did you use?
I replaced coils on my e55 Mercedes about 6 years ago I bought cheap no brand ignition coils which were one-third the price and they have been running excellent with no issues since. So I'm thinking maybe brand isn't so important on ignition coils since it's a simple device?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Oct 30, 2019 | 06:16 PM
JagV8's Avatar
Coils matter a lot. Do not use cheap ones - see existing threads.
It can't flag codes unless it has fairly consistent behaviour.
If you have OE coils, plugs, no changes to other items (avoid K&N, proper fuel, stick to maintenance schedules or better, make sure OBD monitors all set, good battery fully charged, etc), all tends to be OK.
You can get a coil tester.
You can stress them fairly well at say 50mph uphill.
JensenHealey
Jun 16, 2021 02:56 PM
bliving7
Apr 13, 2018 06:51 PM
Kewpie
Mar 4, 2016 02:37 PM
WillieE
May 17, 2011 11:14 AM
MLRocafella85
Dec 29, 2010 11:51 AM
