Lowered my XK for under $40
Old Jul 1, 2019 | 02:39 PM
Ranchero50's Avatar
Originally Posted by Queen and Country
You need spacers not lowering. That will close the gap.
Ding ding, winner right there. Or a little taller tire (did this). Or put the H+R's back on and figure how much taller you want each corner and have some spacers machined (done that before). Or pick up a set of used S type R springs and Lincoln LS sport spring and swap around until you find the "right" stance (done this too before).
The problems with those $10 U bolts is the stresses where the threads started are where it will fatigue crack. China sticker adds to any concerns. In auto sports the one thing you'll read about as gospel is never bind the coils together.
Old Jul 1, 2019 | 03:29 PM
viper1996's Avatar
Well I did find some grade 5 bolts and I will probably switch them over to that with matching nuts. Thank you for your concern though... I just put four new tires on it so larger size and not going to happen at this point0
Old Jul 1, 2019 | 03:51 PM
Queen and Country's Avatar
Originally Posted by viper1996
I did the H&R Springs with 15 mm spacers all around and I still thought it looked too low. Without spacers it looked hideous. I recall a picture of a car with spacers only without lowering and it looked kind of weird not sure if I can find that pic or somebody could
Check out PeterV8's car. It looks good, just follow his formula.
I did not want to rain on your parade and did the irresponsible thing of keeping quite.
Those U-clamps are soft steel, they are not even hardened, even if they miraculously worked, and no way they do even with your double nutting, you are going to have a mess on your hands with rust and your springs will start to rust where they have been cut in.
Dont do it.
p.s. If you are going this route, do what they did in the picture, throw the u shaped all thread away and use grade 5 bolts.
Old Jul 1, 2019 | 04:06 PM
viper1996's Avatar
Thanks do you have a link to that particular thread?
Old Jul 1, 2019 | 04:16 PM
And as Ranch said, go with a taller tire.
https://www.jaguarforums.com/forum/x...pacers-191073/
Thats the before, This is the after
https://www.jaguarforums.com/forum/x...-again-199556/
Hey thats one advantage of black cars, your eye is not drawn to the gap.
Old Jul 1, 2019 | 04:23 PM
viper1996's Avatar
Thanks for the link but that's not going to happen that does not look right. How many people say you shouldn't use spacers either lots of articles on if that's for sure
Old Jul 1, 2019 | 05:11 PM
It is a cheap fix, yes it has some small downsides, which you would not notice, the alternative is expensive wheels.
Unless you want to accept you have a cruiser, and pack that thing with wemin. Then you will get your lowering and who cares what the car looks like. Speaking of, who are you lowering this for.
Old Jul 1, 2019 | 08:29 PM
  #28
viper1996's Avatar
I'm in lowering it for my women of course!
Old Jul 1, 2019 | 10:11 PM
peterv8's Avatar
Adamesh springs lowers 20-25mm. I think H&R lowers 35mm
I have Adamesh springs! Is this to much?
I do have spacers!:-)
Old Jul 2, 2019 | 01:41 PM
  #30
viper1996's Avatar
Peter, That looks really good... I will guess that's a 20MM drop...The Spires are 20MM as well...Do yo have a measurement from floor to top of wheel well front and rear?
Old Jul 2, 2019 | 02:12 PM
  #31
peterv8's Avatar
Could only measure one side cause I parked the car a little carelessly. :-)
Front 69cm, rear 68,5cm
Old Jul 2, 2019 | 02:45 PM
  #32
viper1996's Avatar
Awesome! Thanks...I will compare to mine...
Old Jul 3, 2019 | 11:02 AM
  #33
viper1996's Avatar
Originally Posted by Beau M
I'll help get those crappy H+Rs out of your way, I'll even pay shipping.
Beau is the new owner of my H&R springs!
Old Jul 3, 2019 | 11:10 AM
  #34
viper1996's Avatar
Here are the measurement results compared to Peters 20mm spring drop....27 1/8 mine 27 3/4... I filled the tank and it sits very nice
Old Jul 3, 2019 | 11:56 AM
  #35
I cant believe you are rewarding him. For what??
I was the one to show you dont need springs or lowering.
Old Jul 3, 2019 | 12:25 PM
  #36
Beau M's Avatar
For being a swell guy
Thanks Viper!
Old Jul 3, 2019 | 12:26 PM
  #37
viper1996's Avatar
I'm sorry did you want the springs? Not quite sure what you mean but I do appreciate your advice
Old Jul 23, 2019 | 07:26 PM
  #38
Reverend Sam's Avatar
You can do the same thing for $6 using Harbor Freight tools and zip ties.
Old Jul 29, 2019 | 01:01 PM
  #39
viper1996's Avatar
I put 1000 miles on it with no issues so far...Laugh all you want!!!
Old Jul 29, 2019 | 02:48 PM
  #40
SinF's Avatar
Can you amend your will for a trustee to post here and warn others not to do the same thing?
