Major coolant loss on 11 XK
Old Jul 26, 2022 | 03:07 PM
randyb's Avatar
Default Major coolant loss on 11 XK
So I had a problem with a weeping waterpump and thermostat, fixed those but I cannot see where my major leak is coming from. I have felt with my hands and shined a light, but cannot see any leaks. I can hear gurgling coming when I add a half a gallon of coolant and seems like the leak is somewhere in the lower half of the car. Anyone have any ideas?
Old Jul 26, 2022 | 05:29 PM
jahummer's Avatar
There's a number of plastic coolant pipes and rubber hoses known to be common failure points. Once one leak begins, it's time to start replacing all otherwise you'll be repeating the same labor over and over again.
Old Jul 27, 2022 | 06:27 AM
lear60man's Avatar
Pull the skid plates and grab a flashlight. Behind the engine, on top, is a sneaky one. Look on top of the transmission bell housing to see if it's leaking. Good luck.
Garethster
May 21, 2021 04:12 PM
atlcontracting14
May 10, 2020 03:13 PM
Gremlinx
Apr 17, 2017 07:31 PM
robbing
Dec 21, 2016 10:58 PM
robbing
Dec 1, 2016 02:52 PM
