MAP Sensor Question
Old Jun 7, 2023 | 11:26 AM
MoparDude's Avatar
Originally Posted by sweeper
May be check the map sensor and wiring, also check with another reader as icarsoft is good but I found mine gives some odd readings, if you were producing no boost the car would be very slow, the valve timing and compression is set for boosted engine and in my experience once you lose boost they are very slow.
Will double check MAP sensor and wiring. Could replace MAP sensor just to eliminate that possibility. Currently shopping for a Bluetooth OBDII reader to use in conjunction with Torque app, so may wait and double check with that first.
Old Jun 7, 2023 | 11:27 AM
MoparDude's Avatar
Also did replace the disintegrated boot, the plumbing coupler read from another thread worked a charm.
BuckleSpring
Jul 6, 2021 02:24 PM
stevee D
Jul 28, 2015 06:26 PM
jimangle
Oct 5, 2014 01:48 AM
93greenconv
Jul 27, 2014 09:04 AM
windcaper
Jan 11, 2014 01:47 PM
