Massive coolant leak
Old Mar 19, 2018 | 09:44 PM
dsd's Avatar
dsd
Originally Posted by Cee Jay
Make a mold of the plastic OEM, cast one using alumin(i)um. Cost about $10 and a couple hours work. Course one would need the proper tools.
Commodity 3D printing could help make the mold. There is a special wax filament for metal molds.
Old Mar 19, 2018 | 10:08 PM
Cee Jay's Avatar
"Lost Mold Casting" I'd suppose. Best way to make one.
Old Mar 23, 2018 | 04:48 PM
makecopies's Avatar
Originally Posted by NBCat
Has the water outlet ever been replaced? It must be replaced each time the coolant is changed or it is going to fail.
The JLR part number is AJ811793.
Do you think a I would be able to diy?
Old Mar 23, 2018 | 06:51 PM
steve_k_xk's Avatar
Depends on how competent you are with a wrench
By memory the throttle body has to be removed in order to gain access to the plastic housing then Torx bits will be required .
It's quite a fiddly job definitely not like replacing a thermostat on a SBC
Old Mar 31, 2018 | 01:10 PM
makecopies's Avatar
Default Resolved
Valley pipes .......is what happened seems to be a common Jaguar thing
2 hoses and a couple of gaskets
Old Mar 31, 2018 | 01:55 PM
NBCat's Avatar
Glad you have it resolved.
Did you change the water outlet and thermostat as well?
Old Mar 31, 2018 | 03:02 PM
makecopies's Avatar
Yes I did. I'm starting to feel like what could go wrong next? anxiety feeling now lol
MARK
May 2, 2010 08:41 AM
viscoussquirrel
Feb 12, 2010 08:46 PM
frozinfire
May 1, 2009 10:53 PM
christer200
Apr 8, 2009 03:05 PM
