Mina exhaust + center silencer delete on a 4.2 XKR
Old Nov 4, 2014 | 05:23 PM
8bit's Avatar
Default Mina exhaust + center silencer delete on a 4.2 XKR
Has anyone got a 4.2 XKR with the Mina rear exhaust section AND a mid section with the center silencers deleted and a x-pipe in, like the Spires stage 1?
I already have the Spires stage 1 but am thinking about changing my stock rear section for the Mina one. Curious to hear if anyone's already done the same thing, if so how does it sound? Much drone/booming? Any chance of a sound/video clip?
Old Nov 9, 2014 | 07:27 AM
mosesbotbol's Avatar
Had an X-pipe on my XK; didn't notice a difference, but kept it on.
Old Nov 12, 2014 | 09:20 AM
Big Otter's Avatar
See my recent post about stock vs. Mina: HERE
Please note: 1. This is a regular XK (not "R"), and 2. The Mina has a built-in crossover.
HTH
Old Nov 13, 2014 | 05:44 PM
8bit's Avatar
Great, thanks for that. Sounds like the Mina exhaust is noticeably louder on acceleration in-car than the standard one (with the resonator delete) but about the same when cruising/light-throttle, would you agree with that?
Old Nov 15, 2014 | 06:32 PM
Big Otter's Avatar
My apologies for the delay in responding. Yes, it is louder inside when you're on it but cruising/light throttle is very agreeable. I LOVE this exhaust and am supremely happy with my decision to give it to myself as an early Christmas present.
Old Nov 16, 2014 | 10:18 AM
R_Rated's Avatar
HTH
The Mina is only an axle back... not a catback so that is a little misleading in terms of comparing since all of their competitors are Cat back. The Mina exhaust does not have a built in crossover... It only replaces the rear muffler.
Old Nov 17, 2014 | 06:56 AM
Big Otter's Avatar
That is correct, the Mina is an axle back.
The built-in crossover is inside the rear muffler, per Chris at Mina. It may not be the traditional x-pipe you envision that joins two parallel exhaust pipes, but there is balancing within the muffler, which is why I didn't bother with an x-pipe - it is unnecessary.
Traditionally, the best way to determine the placement of an x-pipe is to put a little bit of paint on the front section of the exhaust, then run the car a bit. Where the paint stops burning is where the x-pipe should be. That being the case, the crossover within the Mina may not be ideal, but it sure does sound good.
kj07xk
Dec 18, 2025 10:56 AM
FrickenJag
Jun 16, 2025 02:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Daim
Nov 28, 2016 09:28 AM
08Z06
Oct 24, 2015 05:46 PM
