Missing remote
Old Feb 19, 2026 | 02:48 AM
alanroberts50's Avatar
Default Missing remote
So I started the car and drove 7mls home and now the remote is not in my pocket! Does that mean it’s still somewhere in the vehicle? Looked all over but I guess I will have to remove the seat ugh.
I assume if the remote fell out of the car before I closed the door and drove home then I wouldn’t have been able to drive home?
Old Feb 19, 2026 | 03:55 AM
User 42324's Avatar
Tried starting the car ? If the key's not seen by the vehicle it won't start.
Old Feb 19, 2026 | 04:08 AM
Yes I can start and drive it so that means it’s def inside?
what happens if I try to lock it using my spare remote?
Old Feb 19, 2026 | 04:39 AM
User 42324's Avatar
Shouldn't lock with a key inside car. Find the key.
BTW, keyless entry cars can be started & will continue to run with key not present.
Old Feb 19, 2026 | 04:59 AM
So now I’m a bit confused, I can get in and start the car and drive it. Does that mean the remote is definitely still inside the vehicle somewhere?
is it difficult to remove the bottom seat cushion? I think it could have gone down the back join between the backrest and bottom cushions it’s not open to the floor so wouldn’t drop through unfortunately
Old Feb 19, 2026 | 05:55 AM
User 42324's Avatar
BTW, keyless entry cars can be started WITH THE KEY PRESENT & will continue to run with key not present.
My reply has been clarified.
Old Feb 19, 2026 | 08:16 AM
wymjym's Avatar
Yes the remote is in the car. I have 'lost' mine several times. Jammed between seat bottom and console. Very hard to see, find, retrieve but there. Try moving drivers seat forward and raise, then from behind seat (while on your knees) use a bright light to determine exact location...good luck.
wj
Old Feb 20, 2026 | 03:25 AM
The “praying position” finally worked and I found it thanks to all!
I think special Jag trousers with zip pockets should be an optional extra!
Old Feb 20, 2026 | 12:58 PM
guy's Avatar
guy
Or put the fob into its cradle
Old Feb 20, 2026 | 04:53 PM
HealeyJag's Avatar
Funny..
Have this problem, only when I wear sweat pants....
Old Feb 23, 2026 | 09:38 AM
luv2fly's Avatar
Hate keyless entry. One of the dumbest ideas ever.
Old Feb 23, 2026 | 10:39 AM
guy's Avatar
guy
Keyless entry isn't the issue. Fob management is.
Old Feb 23, 2026 | 10:59 AM
bocatrip's Avatar
You just saved yourself a minimum of $500+ for a new remote and a reprogramming
Nickts
F-Pace (X761) / C-X17
Jan 27, 2023 09:18 AM
1992weezer
Feb 12, 2018 11:23 AM
dbjenks
General Tech Help
Feb 26, 2017 07:58 AM
Old_Doc
Sep 7, 2014 09:42 AM
