Need advice: XKR 2008 Oil leak
Old May 23, 2024 | 02:24 PM
BenderRodriguez's Avatar
Default Need advice: XKR 2008 Oil leak
Hi Guys!
Will you give me advice please! I have an little oil leak from under the timing chain cover. Mechanic says to replace timing chain cover gasket. For this action do I need to take out the engine? And do I need to disconnect the supercharTer?
Thanks in advance!
Old May 23, 2024 | 02:45 PM
mhminnich's Avatar
Unless he thoroughly sprayed the engine clean and then ran the engine to locate the leak, I'd treat all suggestions of where the leak is originating with a bit of skepticism.
Oil migrates everywhere on a running and driving car. Get it bone dry first. You can also get à UV oil additive to help find where it is originating
Old May 23, 2024 | 02:59 PM
No no, they cleaned the engine!
giandanielxk8
Dec 28, 2025 11:11 AM
Lagonia
Feb 23, 2023 08:55 AM
amtruckn
Apr 24, 2022 11:28 PM
Jim.Carlton
XJ40 ( XJ81 )
Apr 17, 2022 02:11 AM
MikeLss1
Mar 26, 2013 12:41 PM
