Need a part no - Supercharger hose
Old Jan 29, 2022 | 10:01 AM
wsn03's Avatar
Default Need a part no - Supercharger hose
Need a part number that i cant seem to find anywhere.
It is the hose, no 14 on this diagram.
Can anyone help please?
Old Jan 29, 2022 | 10:56 AM
Stuart S's Avatar
Many parts have been discontinued. If you still have the old part, your local auto parts store may be able to match it to something similar.
Old Jan 29, 2022 | 03:10 PM
wsn03's Avatar
Thank you.
As its only an air hose I've decided to replace with silicon hose - it will last much better and is easily available
Old Jan 29, 2022 | 04:21 PM
ralphwg's Avatar
Careful there, that diagram is off an XK8. Not sure if the parts are the same for the X150.
Old Jan 29, 2022 | 06:06 PM
Item 6?
If so, it's showing as available from JLR.
Old Jan 29, 2022 | 09:23 PM
jahummer's Avatar
Originally Posted by wsn03
Thank you.
IF this isn't already known, never replace rigid vacuum hoses with silicone or anything non-rigid, they'll collapse.
Old Jan 29, 2022 | 09:44 PM
Cee Jay's Avatar
Could always do the old timer trick and put a stainless twisty spring-like coil inside like in lower radiator hoses.
Old Jan 30, 2022 | 02:56 AM
wsn03's Avatar
Chaps
Thank you for the answes, really appreciate it. I never use silicone and didn't realise it shouldn't be used for rigid pipes. You've all been a big help.
And yes the later X100 seems to have the same set up / parts?!? Really struggled to find this part, must have been looking in the wrong place - didn't look in fuel and air delivery systems
garethashenden
Aug 5, 2021 12:19 AM
LT1 jaguar
May 21, 2021 04:26 AM
XxSlowpokexX
Oct 14, 2020 03:44 PM
oldtvman
May 25, 2020 10:38 AM
Mekka
Dec 28, 2019 04:37 PM
