Need some help with head gasket repair for Jag xk 2010
Old Sep 8, 2017 | 08:04 PM
Pamela Madison's Avatar
Default Need some help with head gasket repair for Jag xk 2010
What is the cost of a job like this? I know ive seen 3000-7000 but realistically what can i possibly get this done for? Im in Las Vegas. Does anyone know any good shops that can do this job for a reasonable rate here?
Thanks Guys Pamela Im new year so go easy
Old Sep 8, 2017 | 08:12 PM
Ranchero50's Avatar
Can you answer why someone wants the head gaskets changed first? What happened to cause this 'need'? A better description will net a better opinion / answer.
Old Sep 8, 2017 | 08:26 PM
brought it to 2 shops both confirmed it was head gaskets
I know they both were honest about it because they said they couldnt even do the job.
The car when it gets hot has white smoke coming from exhaust. The incident that caused this was I had a total loss of coolant while driving ..
Old Sep 8, 2017 | 08:33 PM
Mandrake's Avatar
The cost is whatever you're quoted. Do some legwork and call around. If they're all within a reasonable amount of each other, then there's your answer.
Old Sep 8, 2017 | 08:41 PM
If anyone had the job done please chime in and if you know of a good place in Vegas for repair.
Old Sep 8, 2017 | 08:51 PM
davchr's Avatar
That is a hard one guess at without seeing it. If it is JUST head gaskets - both sides- I would think $2K max. But if the heads are warped they are about $1000 each. There could be more wrong with it. No one can know the extent of damage until it is torn down.
You need to have someone that can do the work look at it and figure out what is needed and what they want for the job. You can get a motor from a crashed car for ~$5000.
Old Sep 8, 2017 | 09:24 PM
Ranchero50's Avatar
Yeah, that sucks. I'd suspect warped heads but hope it's just the gaskets got cooked. Per what's involved, look at Youtube for 4.0 head gaskets and timing chain stuff. 5.0 will be similar with the exception of the direct injection fuel system. Basically pull the front dress and valve covers, time the engine, lock the cams to the heads (and crank to block if possible). Pull the chains, intake and exhaust bits loose and then lift the heads. Check everything for straightness and signs of leakage by the gaskets. The 5.0 service manual should have the specifics. Google it and download it for free.
Horrible situation, might be simpler to go reman on the engine and swap the whole thing out.
Old Sep 9, 2017 | 04:21 AM
steve_k_xk's Avatar
Love it Ranch you make the job sound very very easy , it's not until you've replaced timing chains and or heads on a quad cam engine do you realise how much of a big job this actually is.
On a positive the head can be replaced with out dropping the engine unlike the audi v8
Unsure if you can or will find a replacement 5l any cheaper than the price to have the head gasket changed
Old Sep 9, 2017 | 02:34 PM
JagRag's Avatar
Kensington Motors Cars are good, but I don't think this will be a cheap fix. Kensington Motor Cars ? Las Vegas' Best European Auto Service Center!
Best to call them and get a quote. Good luck with the repair.
