New Convertible Top Installation
Old Apr 14, 2025 | 11:13 AM
sbolinha's Avatar
Update on my roof: it indeed suffered from the exact same issue as gmuirnz mentioned above: cables almost cut off in the roof loom.
In particular, the "convertible top latch closed sensor" did not give any signal. I could see this in SDD under measurement also.
I soldered the connections and reinforced them. I ended up soldering 3 of the 6 wires. Result: my roof is fully working again.
Additional information: How to diagnose the sensors using a multimeter:
1. Convertible top lid compartment cover piston out sensor (a.k.a. tonneau panel latch sensor): this sensor can be checked by disconnecting the connector to it:
- supply cable, located at the far left side under the tonneau cover: with "contact on", it should read ca. 12 V between the terminals
- cable to the sensor: it should read ca. 1-5 MegaOhm between the terminals
2. Tonneau panel switches are wired in series
- cable to the sensors (in series) it should read indefinite when at least one of the contacts are open, it should read zero Ohm
3. Front latch close sensor and Front latch open sensor: on the roof, under the cover panel, there is a connector with 4 terminals, 2 for each sensor
- the brown cables go to signal ground,
- the coloured cables are the signal feed cables
- with "contact on", it should read ca. 12 V between the each of corresponding coloured and brown terminals.
4. How to diagnose a possible cable loom damage:
- the roof functions partly, but not completely, resulting in a "roof not latched" error
- the roof will not open at all or not close at all
If one of the power supply cables to the roof latch motor is cut off, then the roof latch motor will not work at all.
In all cases, it is best to identify the cable loom as pictured above for a flat spot and cut it open there for diagnosis.
Old Apr 15, 2025 | 04:23 PM
gmuirnz's Avatar
Could be a "sticky"?
Old Apr 16, 2025 | 01:38 PM
powelld91's Avatar
Originally Posted by rfarmery
There looks to be a run on XK replacement tops!!!! My repaired top has separated from the glass for the 3rd time today and it looks that little bit worse each time i repair it, due to the shrinkage of the fabric there is hardly anything for me to re-attach anymore so i am going the same route and look for a new top.
Thankfully OEM+ states a reputable installer within 20 miles of home so i'll be off to talk with them in the coming weeks.
Thank you Stuart for your recommendation.
My searching led me to this item on eBay. It appears to be the HAARTZ German top with glass window with defroster connection for $800. Anybody found a better deal?
https://www.ebay.com/itm/295485385379
Old Apr 17, 2025 | 08:27 AM
Stuart S's Avatar
I bought that top and returned it. It's OK if you want to sell your car. It's cheap for a reason. There's more to a new top than just the fabric. You get what you pay for.
Old Apr 17, 2025 | 08:55 AM
powelld91's Avatar
May I ask what deficiencies you found? I am a new X150 owner, so I am not aware of the pitfalls.
Old Apr 17, 2025 | 09:05 AM
Stuart S's Avatar
Sorry, I don't remember the details. You should just buy it. It's returnable if you don't like it.
Dymaxxion
Aug 19, 2023 06:53 PM
XDriver
Jul 9, 2023 07:42 AM
Oldelance
Aug 25, 2022 08:22 AM
Jagxk891
Apr 17, 2017 03:07 PM
shift
Aug 5, 2015 04:15 AM
