New custom mesh grill install
Old May 18, 2020 | 05:26 AM
peterv8's Avatar
Originally Posted by plc
How and what did you use to shade out the amber reflectors in your headlights
Chrome indicator bulbs.
Old May 18, 2020 | 07:12 AM
plc's Avatar
plc
Read again peterv
I ask about Reflectors not indicator bulbs
Old May 18, 2020 | 07:27 AM
gkubrak's Avatar
Originally Posted by Thorsen
Thanks for the inspiration gkubrak! I went with the black aluminum mesh and decided after making the top piece that I didn't like the way it looked. I ended up blacking out the stock grilles and I'm happy with the way it turned out.
Yeah that looks nice!
Old May 18, 2020 | 07:30 AM
gkubrak's Avatar
Read again peterv
If you pop the lens off your headlight, there is easy access to remove the reflector. I just used some chrome vinyl wrap from the autoparts store to cover it up, then re-installed it. Then slightly tinted the lens.
Old May 18, 2020 | 08:40 AM
peterv8's Avatar
Read again peterv
Ooops, my mistake! :-)
I haven't done anything, they are OEM what I know.
Old May 18, 2020 | 09:06 AM
plc's Avatar
plc
I was asking OP this question which he has answered in post 24 not you
Old May 18, 2020 | 02:09 PM
peterv8's Avatar
Then you have to use quote, as the question came right after my post I figured you looked at my post. :-)
Old Sep 10, 2021 | 09:21 AM
  #28
gkubrak's Avatar
So after someone backed into the Jag in the parking lot, I decided to update the mounting method for this grill.
Some drawbacks from the first iteration:
- The lower grill has almost no support and will split over time from even the slightest bottoming out
- The upper grill is a huge pain to remove with all the glue/epoxy around it. It also doesn't have much support, but it stayed intact.
With the bumper being repaired/painted, I gave the guy my faded hood vents and side grills to repaint also. Came out pretty good but the color doesn't seem right?
This time, for the lower grill, I decided to mount it directly on top of the OEM one. This will give it the support/rigidity it desperately needs! Got rid of the double-sided tape, added some black trim around the whole thing, a few zip ties, and its done.
For the upper, I secured some L-brackets all around using double-sided tape. No more glue/epoxy. Then some nuts, bolts, spacers for the grill. In the future it will be easy to remove the grill and even add some support braces behind the brackets.
Most of the time spent was lining up the grill, measuring to make sure it was centered, then tracing the location of each bracket to make sure it went though one of the diamond holes in the grill.
Final product came out nice and should last much longer:
Old Sep 11, 2021 | 04:14 AM
Roger Cavling's Avatar
Originally Posted by gkubrak
No sunshine coming this week, so here are some pics in the rain...
Overall I love the results! Some minor defects around the edges here and there. But not something the average person would notice.
Will post some more pics in the official picture thread once the sun comes out and I clean it up a bit.
Very nice
Old Sep 16, 2021 | 10:18 PM
  #30
Cee Jay's Avatar
Tinted headlights, good choice. Now to subdue the chrome washer trim pieces.
Old Sep 17, 2021 | 11:34 AM
  #31
gkubrak's Avatar
That was an old pic. I only put the tint on because the headlights look so out of place and shiny with the OEM grill.
I've since taken it off and re-finished the lens. With this grill the headlights don't look so out of place.
But yeah the chrome lids did stand out... in a 'twinkle in your eye' kind of way.
BruceTheQuail
Sep 12, 2021 03:40 AM
StormtrooperFtype
Oct 19, 2019 01:58 PM
AlexJag
Oct 8, 2019 08:19 PM
mbates50
Mar 18, 2016 03:05 PM
04xtype04
Nov 26, 2013 01:23 PM
