Now i cant get out of park and wont start
Old Jul 17, 2017 | 04:03 PM
sov211's Avatar
Originally Posted by sherbercars
Yes I agree and will do today . But I still Need to remove the trim and figer out how to get the car running . Im 100 miles from the nearest Jag Shop. and they wont let me speak to a machcanic . Bernie
Bernie: you start be removing the wood finisher - using plastic trim revolver tools you gently lever UP at the front (ashtray end) and then along the sides to release the tabs from the clips. Now unscrew the shift knob - if it has not been off before it will be very stiff - but it does just unscrew. Normally the shift lever should be in N to facilitate removal of the wood and gear escutcheon (they come off as one piece) but you should be able to manoeuvre it off.
Before you do any of this ( and I note that you have said you followed all suggestions) do look at the battery again because I suspect that this is the source of your problem.
Old Jul 17, 2017 | 04:16 PM
sherbercars's Avatar
Thanks. The Batt. is showing 12 v and im using a mobile booster that puts out 13v.
Old Jul 17, 2017 | 04:33 PM
sov211's Avatar
If the battery is showing just 12 volts, it is not at full charge. I have no experience with a mobile booster but the vast majority of issues with these cars are related to the various modules not getting full voltage (hence the suggestions regarding the use of a battery maintainer).
Old Jul 17, 2017 | 05:22 PM
davchr's Avatar
... if I jack up the rear wheels the front brakes appear to go on ,so I cant move it anyway ...
There is no reason the front brakes should go on, unless you press on the brake pedal. The front brakes are not actuated with the parking brake.
Old Jul 17, 2017 | 06:11 PM
myexcursion's Avatar
Pick up a battery for under 200 bucks and give it a shot if you don't have a spare one from another car. Eveything seems to point to battery. A lot cheaper then towing to a dealer , or ...
Had similar symptoms of parking brake error and car would not turn over at all about 2 weeks ago. I put on my neighbor's battery tender plus for almost 2 days. Car started right up after that. I went on Amazon and picked one up for myself
Old Jul 18, 2017 | 12:35 AM
Yes I cant understand that , but I tried it 3 times without pressing the pedal. ?
Old Jul 18, 2017 | 01:27 AM
OK. IM going to bite the bullet . Removed the batt It is , a 5yrs old Interstate Mega Tron Plus 85 . MTP-49/H8 100 AH . I do not beleve it is a AGM ??. Hope you are all right . but its time for a new Batt. anyway.
Old Jul 18, 2017 | 05:38 AM
  #28
kj07xk's Avatar
Before connecting the new battery, touch your cables together to drain any residual charge that may be holding some module in a wonky state.
Old Jul 18, 2017 | 08:43 AM
and if you have press the brake pedal more than a few times since starting it last, you will need to really press down HARD on it when the new battery goes in and you go for the start/stop button...
Old Jul 18, 2017 | 09:28 AM
  #30
Stuart S's Avatar
Press the START button before you step on the brake pedal.
Old Jul 18, 2017 | 11:45 AM
  #31
Queen and Country's Avatar
If the car is outside the garage when the forest fire comes, you will have to pay separate deductible for the car.
Old Jul 18, 2017 | 03:17 PM
  #32
Just had the Batt. tested at 3 places, one shows replace. two show good . all show 12.65 v all tested at 650 cc. draw down to 550. anyway I purchased a new 800 cc batt ,Delco acid . no one in our small town can get a AGM. nearest Jag shop 100ml.
Will install this afternoon . with fingers crossed.
Old Jul 18, 2017 | 05:52 PM
  #33
Well new Battery installed fully charged. And nothing has Changed. very unhappy with Jaguars . I guess its the 100 ml. tow to jag shop.
Old Jul 18, 2017 | 06:14 PM
  #34
tberg's Avatar
sherbercars,
This exact same scenario happened to my 2010 XKR about 3 weeks ago. Could not start, could not get out of gear, would not jump, got a brand new battery, and nothing happened. DEAD!!!! Even AAA came out and told me the battery was no good even though it was only a year old. I exchanged it for a new one with no success. Was able to get the car out of gear through the emercency release located in the console. Had it towed to my mechanic where it was diagnosed as the starter. Replaced the starter, cost me $350.00, and everything is back to normal.
Old Jul 18, 2017 | 06:52 PM
  #35
Originally Posted by tberg
sherbercars,
Thanks T. Yes I received your post earlier , my problem is being stuck in park where it is . I had a tow truck down but its hard to get at. Q.C says I wont be able to release it that way ?? perhaps you can enlighten more on the procedure , im at a loss
I build classic type modified cars for a hobby and do all my own work . but this computer stuff has me beat.
Old Jul 18, 2017 | 07:30 PM
  #36
While the battery was disconnected, did you short the negative and positive to reset the computer?
Old Jul 18, 2017 | 07:39 PM
  #37
That and press real HARD on the brake pedal.
Good luck !
Old Jul 18, 2017 | 07:59 PM
  #38
I I think so I linked them together as was sujjested to get rid of the power in the line , is that what you mean , is there a trick to that as well. Bernie.
Old Jul 18, 2017 | 08:12 PM
  #39
Good luck !
Yes and stood on the brake pedal.
Old Jul 18, 2017 | 08:54 PM
  #40
one more thing.
Lock the car- then unlock it.
Then dont touch the brake and press the start button.
(they are rarely ever tricky- if just once)
