O2 sensor codes - P0031 P0036 P0051 P0056
Old Jul 20, 2017 | 03:56 AM
8bit's Avatar
Default O2 sensor codes - P0031 P0036 P0051 P0056
Scanned my car (4.2 X150 XKR) for fault codes last night and found four, one for each of the four O2 sensors in the exhaust - P0031, P0036, P0051 and P0056.
Strikes me as unlikely that all four have failed at the same time. Looks like they're fed from two fuses (F33 and F34) in the engine bay fusebox and a relay (R12A) prior to that. Anything else I should check? Anyone know where the wiring from there runs?
Old Jul 20, 2017 | 08:39 AM
Snide72's Avatar
My only thought is ... why aren't you watching THE OPEN instead?
Old Jun 7, 2020 | 04:59 PM
silvertonesx24's Avatar
Just got the same here, all 4. This ever get resolved?
Old Jun 7, 2020 | 05:03 PM
My fuses 33 and 34 look OK
Old Jun 8, 2020 | 07:09 AM
8bit's Avatar
No, I never got to the bottom of that and eventually traded the car in. Suspect it could have been low battery voltage or they tripped sometime I had the battery disconnected.
Old Jun 8, 2020 | 07:36 AM
Thorsen's Avatar
What are your long-term fuel trims?
When the car is running, can you use your scanner to watch the o2 sensor voltage?
mlohmiller
Jul 13, 2018 04:30 PM
shtse73
Nov 13, 2014 10:50 PM
omcstan
22
Apr 24, 2013 08:25 PM
hankycbr
Aug 14, 2008 01:37 AM
tap
May 14, 2008 04:16 PM
