Odd problem with Sat Nav
Old Jul 4, 2017 | 01:47 AM
u102768's Avatar
I wonder why some people with 5.0L cars don't have it then. Has anyone tried checking the menu to see if it is a switchable option as per the XF?
Old Jul 4, 2017 | 11:13 AM
carealtor's Avatar
Originally Posted by u102768
I assume that the way to turn it on is similar to how it is done in the XF:
TURN-BY-TURN NAVIGATION
Turn-by-turn navigation guidance (displayed in
the message centre) can be turned on or off as
follows:
From the main navigation menu, select
Navigation Setup, then select User Settings.
Scroll through the user settings list until the
Message centre guidance band is displayed.
Touch the band to select/deselect the feature.
If the band is dark blue, then Message centre
guidance is active. If the band is light blue,
Message centre guidance is turned off.
My old X350 used to do it as well and that could be turned on and off in the nav setup menu.
I played with this a bit in my 2012. I found that there is indeed a setting for this as described in the previous post. However, the coloring is the opposite for me. The Message center guidance is on when the band is light blue and off when dark blue.
