Odd squeal
Old Aug 16, 2019 | 07:55 PM
buddhaboy's Avatar
Default Odd squeal
The old girl is squealing and not in a good way me thinks. Inside the cabin it sounds like it's coming from the dash, but I realize
that it could be originating from anywhere. Ah, but what does it sound like? Well, it's sort of between a squeal and a screech, less
on the screech, but there is a random hint of it. Disappears at a stop, and seems unrelated to engine or RPM as engine speed does not
change it.
It sounds rotational, but the pitch and frequency stays fairly constant once it's a speed. Does not change with road speed.
Only happens when car is moving. I dropped it into neutral at 60 and coasted to 20, which had no effect on the sound, which
stayed relatively constant.
I thought wheel bearing, maybe a spun race, but also thought it would change with wheel speed. I dunno.
Help.
Old Aug 16, 2019 | 07:57 PM
Cee Jay's Avatar
Was your climate system active? Could be a failing blower motor.
Course, some people have reported a hiss-squeak thing from a bad seal on the A/C high pressure line.
Old Aug 16, 2019 | 08:20 PM
buddhaboy's Avatar
It seems unrelated. When idling the car is quiet, with or without the climate system engaged. It only resurfaces when rolling.
Old Aug 17, 2019 | 01:07 AM
Woo5ie's Avatar
Sounds like it’s got to be wheel related. Perhaps a stone stuck between a brake disc/rotor (as they are over there)
and the rotor cover. Or as you say a wheel bearing .
Old Aug 17, 2019 | 09:57 AM
George05's Avatar
Sounds wheel related to me to , could be a sticky caliper piston
Old Aug 17, 2019 | 10:03 AM
buddhaboy's Avatar
It's the shock mount, which explains why the frequency and speed doesn't change.
cheers
Old Aug 24, 2019 | 06:34 PM
Billieg's Avatar
Yep, it's the shock mount. Just WD-40 the top of the mount real good and it will go away. Ask me how I know.....
ltmax
Jun 15, 2024 05:15 AM
wcourt3010
Sep 23, 2015 01:06 PM
Gergs
Nov 10, 2010 02:58 PM
tc80211
May 4, 2010 10:51 AM
Raheny
Mar 4, 2009 08:00 AM
