Oil Change How to
Old Mar 23, 2012 | 08:23 PM
Chaos236's Avatar
Default Oil Change How to
Want to change the oil on my 07 XK,search came up 0.
Old Mar 23, 2012 | 08:56 PM
axr6's Avatar
The last time I did an oil change on my '08 XK was last July, so I tend to forget little details; having said that, you raise the front end and remove the rear belly pan by taking out 4 small fasteners bolts. Once removed it is easy access to the oil drain plug and to the oil filter. Should take no more than 0.5 hours in a home environment.
Albert
Old Mar 24, 2012 | 04:34 PM
Chaos236's Avatar
All done,I have a lift and a oil catch can.
Thanks for the tip.
Old Mar 26, 2012 | 01:17 PM
Chaos236's Avatar
7 quarts
Old Mar 26, 2012 | 04:24 PM
mosesbotbol's Avatar
I thought there was some "mis-information" floating around on how much oil the 4.2 V8 takes? Not saying it is not 7 quarts
aholbro1
Dec 29, 2024 06:46 PM
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
ZJag
26
Sep 5, 2016 03:33 PM
Scarecrow
Mar 28, 2016 03:17 AM
teacoff
Sep 10, 2015 08:25 AM
