Oil change reset
Old Jan 12, 2020 | 10:02 PM
d a's Avatar
d a
Default Oil change reset
Changed the oil/filter yesterday and all went well except I didn't get the dash notice to reset oil monitor. Is that normal? Should I go through the reset process anyway?
Old Jan 14, 2020 | 09:25 AM
neilr's Avatar
It is not really actively monitoring the oil, is it? It counts down the elapsed time since the last reset and monitors drive patterns, calculating a reduced period if you are doing a lot of short journeys, hard driving or whatever was programmed into the algorithm. Just reset it and restart the cycle.
Old Jan 15, 2020 | 08:24 AM
DGL's Avatar
DGL
When you follow the reset procedure make sure the mileage meter is showing and not the trip meter. It will not message you "service required reset confirmed" if you don't. I got tripped up with this, LOL.
Old Jan 15, 2020 | 09:58 AM
d a's Avatar
d a
I didn't know there was no active monitoring. So there aren't any sensors checking actual oil condition for breakdown? Especially since we can't pull a dipstick and look for ourselves, wow.
Old Jan 16, 2020 | 03:34 AM
neilr's Avatar
How would this be done? And is there any real value in it as if you use good oil, it should outlast the service interval. One doesn't need any more.
ecamiel
Apr 11, 2020 09:48 PM
romroc
Sep 25, 2019 07:09 AM
mick99
Sep 7, 2016 09:38 AM
Rique
Apr 18, 2012 06:50 PM
pdog2000
Feb 1, 2012 10:39 AM
