OIl changes XKR 2008-2009
Old Jun 7, 2013 | 07:32 PM
richzak's Avatar
Default OIl changes XKR 2008-2009
I would like to know if anyone here does their own oil changes on their XKR 2008 or 2009? They have an oil drain plug, so no oil has to be sucked out of the engine.
Also, if you don't do your own oil changes, do you use the dealer or a local mechanic that is familiar with these models?
Does anyone use a national brand oil changing store like Quik Lube, Jiffy Lube etc for this basic service. ?
I am told the dealer will charge around $120.00 for the oil change.
Your thoughts on this topic are appreciated.
Old Jun 7, 2013 | 09:42 PM
ralphwg's Avatar
I have used the dealer for oil changes. When I had my 2008 I would have the oil changed every 5000 miles until my service writer told me to quit wasting money and change oil at a minimum of 10,000
miles. He said that the new oils and engines are engineered to last longer without the danger of any excess damage.
Old Jun 7, 2013 | 09:48 PM
CleverName's Avatar
I let Jiffy Lube do mine. Basic filter and oil change every 3000.... Zero issues.
That's just how I roll...
Vince
Old Jun 8, 2013 | 05:58 AM
ctsemicon's Avatar
Default Oil changes
I do my own oil changes. Quite simple. I use Shell Rotella T-6 Synthetic Oil, nicely comes in 4 qt container and you can get it at numerous places. i use K&N Oil Filters (HP-1014).
I did note, first time I did it, the oil pan had slight seepage and there was nasty oil/dirt build up at lip. I dropped pan, found oil pan seal (molded o-ring) was slightly twisted during factory install). I reseated o-ring with very thin film of gasket sealer applied...no more seepage.
Do It Yourself, good for your car karma!
Old Jun 8, 2013 | 10:05 AM
Mike V's Avatar
Default +1
DIM
It's like taking the wife out to dinner for your anniversary and enjoying some alone time.
I'm on the every 10k interval as well.
Old Jun 8, 2013 | 10:35 AM
mosesbotbol's Avatar
I bring to my indie jaguar place. I buy Baldwin filters online and let the mechanic buy the oil which is usually Mobile1. I like to have my mechanic be the only one doing the oil so I can get some lift time and routine underneath inspections.
It was on my spring oil change that is was found my transmission pan was leaking. Yeah for him, it was 1.5 hours to swap the pan, new fluid, and $550 to me. He's seen a few with leaking pans recently.
Old Jun 8, 2013 | 12:20 PM
Louenigma's Avatar
Please see my post about oil changes,
Thanx,
https://www.jaguarforums.com/forum/x...-please-95966/
Old Jun 10, 2013 | 11:45 AM
richzak's Avatar
How accessible is the oil filter on a 2009 XKR 4.2L SC?
Old Jun 11, 2013 | 02:04 AM
Mike V's Avatar
Default Next to drain plug
Remove the rear under tray and you'll see the drain plug and the oil filter. Tip: you can leave the front under tray connected to the front bumper in place.
Old Jun 11, 2013 | 08:10 AM
Donzi's Avatar
Good tip, thanks! I do all my oil changes and never trust the cheepy quick change places!
Old Jun 11, 2013 | 08:22 AM
Executive's Avatar
Yea, i would stay away any place with a "jiffy" attached to it.
If you can do it yourself, good, but if not, the dealership is a good place. And, you don't have to worry about anybody jumping in your car with dirty/oily clothes. My dealer covers the seats etc..
Old Jun 11, 2013 | 08:36 AM
amcdonal86's Avatar
Oil changes are not for me. I did them in the past in college on other cars, but you begin to realize that 1) you don't really save much money, and 2) it's a huge pain in the butt to put the oil in a greasy container and lug it in your trunk to the recycling center/auto parts store. What a mess!
Old Jun 11, 2013 | 12:37 PM
Yup.
Old Jun 11, 2013 | 12:53 PM
axr6's Avatar
Makes sense what you say but, for me personally it is much more of bother to take my car out for an oil change and wait for it done. It takes me about 15 minutes to change oil and filter and and an other 5 minutes to clean up. To drive to the nearest dealer would be 1 hour each way. I'm already dreading the fact that I have to drive to the dealer twice within the next 2 months, get a loaner car, drive back again to drop the loaner... when I get my warranty services done for my 2012 XJL and XF.
Changing the oil also gives me an opportunity to look around the car to see if everything under and in the engine compartment is what it should be.
Albert
Old Jun 15, 2013 | 02:21 PM
richzak's Avatar
Just back from Jaguar dealership in El Paso, TX (Garcia Jaguar).
Oil change...... oil, filter, inspection of all fluids, and install 2 light bulbs in trunk lights....great service overall. $121.00 vs local foreign car repair shop @$90.00.....so it was worth the drive over to the dealer today to let a certified Jaguar mechanic do the work.
Car is now registered in their system.
mrplow58
Jan 21, 2024 05:53 AM
GordoCatCar
Jan 2, 2017 01:10 PM
Scarecrow
Mar 28, 2016 03:17 AM
Gerard Radimaker
Sep 13, 2015 10:33 AM
teacoff
Sep 10, 2015 08:25 AM
