Oil Leak..From Somewhere? Thoughts?
I'll add that the Jaguar Manual recommendation is Shell M1375.4 which Mercon SP meets as does Ravenol, Pentosin ATF. Valvolene has a product out there too. So I suspect when the transmission was originally developed, the fluid specs were probably only met by ZF but as time passes and as with other parts, Non OEM catches up.
The following 3 users liked this post by Sean W:
I feel pretty stupid in hindsight even suggesting the possibility of the Ravenol fluid. (its good fluid but)
If this was the Mars Rover, I would be fired on the spot.
Boss would say 'Let me get this straight; transmission manufacturer makes a fluid, its proven, but to save $5 a liter on something you wont do for another 8years, you picked the devil you dont know. Managers at in-n-out burger make $140k, get an application.'
Received 1,896 Likes
Since the OP won't know if it is actually a transmission leak until someone looks from underneath, I'll just toss this out there...
I had dripping from the rear of my transmission cover, but it turned out to be an oil leak, due to some numb-nut not having tightened one of the bolts on a valve cover.
Had no oil drops on the garage floor for 3 years, until starting the car up on a cold day, and the valve cover seal allowed the leak.
The story is in this thread: https://www.jaguarforums.com/forum/x...l-leak-199975/
Just a thought, until we hear the results from the OP.
Queen and Country (01-10-2019)
Received 6,253 Likes
The following 2 users liked this post by Sean W:
Cee Jay (01-10-2019),
TexasTraveler (01-10-2019)
Sean W (01-10-2019)
#28
Peter
Received 2,579 Likes
If the pan Torx bolts are a concern, you can order them separately:
https://www.ebay.com/itm/For-BMW-E60...wq-:rk:20:pf:0
As well as the Lifeguard6 fluid:
https://www.ebay.com/itm/NEW-BMW-Jag...QRv:rk:10:pf:0
kj07xk (01-10-2019)
#30
[QUOTE=NBCat;2011789]If the pan Torx bolts are a concern, you can order them separately:
Just an update
The first company you provided had the better deal on the bolts. Because they are noted as improved larger head. The ebay company does not give the head size.So if its for the older torx 28, it would not be as good.
https://www.thectsc.com/products/oil...pan-28-10.html
Just an update
#31
Is the following kit the right one for our vehicles? Seems like a pretty good deal, considering what you get...
https://rimmerbros.com/Item--i-LR007...RoCtK0QAvD_BwE
Maybe not enough fluid to completely fill it after a change, but if the shop/person doing the work has some on-hand, should be OK. I used just over nine quarts, would have been more than two quarts short if I'd have bought this one.
Far as the pan/filter go, I'd not be surprised if ALL the available pan/filters available are made by the same one manufacturer.
Mechatronic (??) sleeve, not really much to that.
#33
sorry for the late update...
folks,
thank you again for all the help on my leak situation. as always...the experts on the site were correct and the car is now fixed. it was in fact the plastic transmission pan. I took it to Coventry Jaguar in san diego for the repair. they were nice to deal with and took car of my car as I needed. they noted the car was in as new condition and appreciated how fastidious I have been in taking care of the car. they did not disappoint. thanks again folks!!
gbmtkj
12-29-2014 09:13 AM
Canard
04-09-2014 07:51 PM
newuser
04-17-2010 11:35 AM
