Oil Leak..From Somewhere? Thoughts?
Old Jan 10, 2019 | 09:37 AM
Sean W's Avatar
I'll add that the Jaguar Manual recommendation is Shell M1375.4 which Mercon SP meets as does Ravenol, Pentosin ATF. Valvolene has a product out there too. So I suspect when the transmission was originally developed, the fluid specs were probably only met by ZF but as time passes and as with other parts, Non OEM catches up.
Old Jan 10, 2019 | 10:44 AM
Queen and Country's Avatar
I feel pretty stupid in hindsight even suggesting the possibility of the Ravenol fluid. (its good fluid but)
If this was the Mars Rover, I would be fired on the spot.
Boss would say 'Let me get this straight; transmission manufacturer makes a fluid, its proven, but to save $5 a liter on something you wont do for another 8years, you picked the devil you dont know. Managers at in-n-out burger make $140k, get an application.'
Old Jan 10, 2019 | 11:05 AM
kj07xk's Avatar
Since the OP won't know if it is actually a transmission leak until someone looks from underneath, I'll just toss this out there...
I had dripping from the rear of my transmission cover, but it turned out to be an oil leak, due to some numb-nut not having tightened one of the bolts on a valve cover.
Had no oil drops on the garage floor for 3 years, until starting the car up on a cold day, and the valve cover seal allowed the leak.
The story is in this thread: https://www.jaguarforums.com/forum/x...l-leak-199975/
Just a thought, until we hear the results from the OP.
Old Jan 10, 2019 | 11:48 AM
John Nevets's Avatar
I know I'm new around here, but would you seriously consider using something called Mericon in a historically British car, with a German transmission. That just seams wrong, and please no "Make Mericon Great Again" jokes. ;-)
Old Jan 10, 2019 | 12:04 PM
Just to add to the confusion, here's some German fluid that conforms can be founfd for ~$15/litre
Sean W's Avatar
Ford made my car. Tata Motors made the newer XK's. Yep, you're new.
Old Jan 10, 2019 | 12:17 PM
Just pointing out...by that formula-Sheikh Sohaib Ahmed bin Muhammad makes Aston Martins.
Do we really want to pop all the feel good balloons in the room.
Old Jan 10, 2019 | 02:30 PM
  #28
ferraripete's Avatar
I don't know when I will be able to confirm for the group the issue as I have two weeks of east coast travel ahead of me. I have ordered the kit already but did not get the extra fluids or bolts as recommended by the group...I had order the kit prior the additional fluid and bolts suggestions. I will let everyone know what we come up with and again, thank everyone for the help and guidance.
Peter
Old Jan 10, 2019 | 02:48 PM
NBCat's Avatar
If the pan Torx bolts are a concern, you can order them separately:
https://www.ebay.com/itm/For-BMW-E60...wq-:rk:20:pf:0
As well as the Lifeguard6 fluid:
https://www.ebay.com/itm/NEW-BMW-Jag...QRv:rk:10:pf:0
Old Jan 10, 2019 | 06:50 PM
  #30
[QUOTE=NBCat;2011789]If the pan Torx bolts are a concern, you can order them separately:
Just an update
The first company you provided had the better deal on the bolts. Because they are noted as improved larger head. The ebay company does not give the head size.So if its for the older torx 28, it would not be as good.
https://www.thectsc.com/products/oil...pan-28-10.html
Old Jan 10, 2019 | 07:46 PM
  #31
Cee Jay's Avatar
Originally Posted by TexasTraveler
Is the following kit the right one for our vehicles? Seems like a pretty good deal, considering what you get...
https://rimmerbros.com/Item--i-LR007...RoCtK0QAvD_BwE
Doesn't seem too bad, makes it easier than ordering three things.
Maybe not enough fluid to completely fill it after a change, but if the shop/person doing the work has some on-hand, should be OK. I used just over nine quarts, would have been more than two quarts short if I'd have bought this one.
Far as the pan/filter go, I'd not be surprised if ALL the available pan/filters available are made by the same one manufacturer.
Mechatronic (??) sleeve, not really much to that.
Old Jan 10, 2019 | 07:51 PM
  #32
TexasTraveler's Avatar
Cee jay I agree with you about having enough fluid, that’s why after researching today I went ahead and ordered the same materials that you did... Thank you for the links...
Old Apr 20, 2019 | 03:04 PM
  #33
Default sorry for the late update...
folks,
thank you again for all the help on my leak situation. as always...the experts on the site were correct and the car is now fixed. it was in fact the plastic transmission pan. I took it to Coventry Jaguar in san diego for the repair. they were nice to deal with and took car of my car as I needed. they noted the car was in as new condition and appreciated how fastidious I have been in taking care of the car. they did not disappoint. thanks again folks!!
gbmtkj
Dec 29, 2014 09:13 AM
Canard
Apr 9, 2014 07:51 PM
gkazimir
Aug 7, 2013 12:12 PM
newuser
Apr 17, 2010 11:35 AM
