Oil Leak- Vacuum Pump Seal?
Old Nov 22, 2020 | 11:46 AM
EastCoastYost's Avatar
Default Oil Leak- Vacuum Pump Seal?
Noticed a bit of oil on the garage floor. Got the car up and got underneath to inspect and cleaned.
Looks like it is coming from around the vacuum pump, which has been known to be an issue on other 5.0's (haven't found similar here). Examples here XFR XJ
I want to replace the seal. Have found PN C2D3771 but it doesn't list the XKR for compatibility as far as I can tell and have not been able to find a PN for our car. Looking for any suggestions.
Not driving much except to test, monitoring oil level as best I can.
Old Nov 24, 2020 | 01:17 AM
trkyam's Avatar
They are the same vacuum pump as far as I know, usually just the seal is replaced, and there
are updated bolts as well, they stopped using the torx bolts and use metric standard bolts now.
Bradleydriven
Aug 6, 2023 07:49 AM
Mish_Mish
Sep 29, 2016 09:50 AM
Roger95
Jul 23, 2014 10:22 AM
RRT
Jun 17, 2013 06:03 PM
Dan
Sep 20, 2012 10:23 AM
