XJ ( X351 ) 2009 - 2019
Overheating and oil leak
Old Jan 4, 2020 | 07:54 PM
Bradleydriven's Avatar
Default Overheating and oil leak
I have a 2011 5.0 xjl I was sitting in it one day with the heat on and it started overheating turned it off immediately couple hours later came back checked coolant level and it was normal then a couple weeks later same thing replaced thermostat and got an oil change learned that I have an oil leak too along with the same overheating problem need help finding the issue
Old Jan 4, 2020 | 08:56 PM
Nedoerr's Avatar
Looks like your brake booster vacuum pump. It is a common spot for an oil leak. The o-ring can be replaced or you can buy a new vacuum pump. I did the latter not knowing at the time that the gasket could be replaced.
All the best.
Old Jan 12, 2020 | 01:13 PM
Sean Mc's Avatar
The oil leak at the vacuum pump is not causing your overheating. That is a common spot for a leak and and easy fix.
Your engine is all aluminum. Overheating will destroy it very quickly. You need to find the cause and remedy before you blow the head gasket.
Old Jan 12, 2020 | 02:06 PM
I changed my thermostat and no more overheating issues and I ordered the seal for the vacuum pump but it’s on back order
Old Jan 12, 2020 | 05:28 PM
clubairth1's Avatar
Community Influencer
Any chance you have a part number for the O-ring on the vacuum pump?
Old Mar 12, 2020 | 09:35 PM
12jagmark's Avatar
Maybe C2D3771(?)
I think I need one too, and did a quick search for a 2012 Jaguar XJ brake vacuum booster pump seal (and "kit" came up, to finish the search criteria)
https://www.jaguarmerriamparts.com/o...p-seal-c2d3771
Old Mar 13, 2020 | 10:55 AM
clubairth1's Avatar
Thanks as I believe you found it!
Old Jul 24, 2023 | 03:57 PM
Erhead64's Avatar
Old Jul 24, 2023 | 03:59 PM
Erhead64's Avatar
Default Vacuum pump repair o ring kit
Old Jul 31, 2023 | 06:43 PM
fossberry's Avatar
Originally Posted by Erhead64
That's the one that's leaking on mine - not the seal between the pump and the engine block (which is the part number what's quoted above) so am watching this thread too
Old Aug 6, 2023 | 01:53 AM
fossberry's Avatar
Default The O-ring seal kit
Found it here...everything needed to ensure it doesn't leak:
https://a.co/d/6MPIV95
RKX Vacuum Pump Rebuild Seal kit. Have ordered this kit to fix the leak on my portfolio 👍🚗
Old Aug 6, 2023 | 07:49 AM
clubairth1's Avatar
Great find!
Thanks for posting back with that.
Xjgrey
Dec 12, 2021 06:04 PM
1bad55chevy
Dec 28, 2017 09:04 PM
avisjaguar
May 2, 2017 03:07 PM
04xtype04
Feb 27, 2014 08:22 PM
Rockyf
Oct 28, 2010 01:24 PM
