oil question
Old Aug 20, 2011 | 06:51 AM
Jeffrey Brewer's Avatar
Default oil question
Sorry I tried search - something not working correct, type in word "oil" search finds nothing???
I have converted all my prior vehicles Jags included to full synthetic oil. All break-in periods have been with non-synthetic, I feel this has served me well. Any thoughts or recommendations on the XKR?
Old Aug 20, 2011 | 08:04 AM
Mikey's Avatar
'Oil' is only of the most frequently discussed topics here- and often turns into the most heatedly debated topic as well. Attempting to get people to come to a consensus on which type is best is futile. If the owners manual makes no mention against using syn, then choose the viscosity that suits your climate and away you go.
Old Aug 20, 2011 | 02:38 PM
Stuart S's Avatar
From what I've read, and I'm not a petroleum engineer, synthetic oil "drains down" from the cylinder walls far more slowly than does dino oil. So, if you rarely drive your car, you're much better off with synthetic oil since it will better protect your engine at start-up. Also, how you drive (engine rpms, trip length, climate/temp/dust/etc.) also play a role. Oil, both syn and dino, never wears out; it just gets dirty and the additives lose their efficacy. Either one can adequately protect your engine, provided it meets the manufacturer's specs. Stop/go short trips are engine killers, since the water in the crankcase never gets hot enough to evaporate. Note that H2O is a natural by-product of internal combustion; you can see it dripping from your tailpipe sometimes, and as a cloud of water vapor when it's cold outside. If you rarely drive your car, you should change your oil (syn or dino) at least once a year or preferably sooner, since water in the crankcase can become corrosive. Oil is cheaper than engines. Just my $0.02.
Old Aug 25, 2011 | 01:55 PM
Chaos236's Avatar
Redline and Brad Penn are good,try a oil analysis from Blackstone labs,very interesting data.
ZJag
26
Sep 5, 2016 03:33 PM
Scarecrow
Mar 28, 2016 03:17 AM
teacoff
Sep 10, 2015 08:25 AM
giandanielxk8
Sep 6, 2015 07:21 PM
Dymaxxion
Sep 4, 2015 02:40 PM
