oveheated differential
Old Jul 30, 2012 | 03:23 PM
abela's Avatar
Default oveheated differential
I have a 2009 XKR and the rear wheels froze completely . the car was towed into dealership where I was told that there was a slow leak of a gasket and all differential oil was lost whuch caused differential to overheat....is this a common problem for 2009 XKR ?
Old Jul 30, 2012 | 07:45 PM
mosesbotbol's Avatar
Wow, that is uncommon on any car.
Old Jul 30, 2012 | 09:13 PM
amcdonal86's Avatar
That is shocking! I guess this is why it's important to park in the same parking spot every day and keep an eye out for leaking fluids.
Old Jul 30, 2012 | 09:27 PM
WldCat's Avatar
It was a recurring problem in early Cadillac CTS sedans; a small number of owners had the rear wheels seize *while at speed* but fortunately, no fatalities. GM issued a recall and offered an extended warranty for the replaced differentials. Seizure was blamed on faulty pinion seal that resulted in diff fluid leak.
I assume they are replacing the entire differential?
Old Jul 30, 2012 | 09:37 PM
cpf's Avatar
cpf
Was it under warranty ? Is there any way us to check our diffs ?
Old Jul 31, 2012 | 07:44 AM
abela's Avatar
Yes it was quite shocking... I don't know if there is a way of cheking this, other than parking in the same spot and verifying the area for oil leaks. It is still under warranty. Thank you for your comments.
Old Jul 31, 2012 | 10:02 AM
CleverName's Avatar
I noticed a while back that there. was a TSB discussin the need for different drive shafts if the diff was replaced..... I cant help but wounder if the two are related... . Glad to hear your covered!
Vince
hoodun
May 15, 2019 09:31 PM
Dave1109971
Dec 15, 2015 06:16 PM
Woznaldo
Sep 26, 2015 11:02 AM
AtholC
Sep 9, 2015 09:07 PM
