over heated
Old Apr 26, 2018 | 05:38 PM
stahoo's Avatar
Default over heated
2011 jag supercharge over heated. is the engine shot?
Old Apr 26, 2018 | 05:41 PM
Mandrake's Avatar
Kinda hard to tell when we're all looking at our computers instead of the inside of your engine. You should probably take it to a shop and let them answer that for you.
Old Apr 26, 2018 | 06:09 PM
stahoo's Avatar
I did they tried to sell me a new engine. Didn't evan look into the engine.
Old Apr 26, 2018 | 06:52 PM
sparky fuze's Avatar
What if any symptoms is the engine now displaying?
Is it seized?
Does it start?
Is it blowing any smoke? If so, what Colour?
Is there any antifreeze getting into the oil? (Milky coloured oil?)
Is it making any strange noises? Knocking?
Is there any lack of power?
Is there anything unusual about it now that wasn't there prior to over-heating?
How long was it running after getting too hot?
Is it using excessive amounts of oil?
Cee Jay's Avatar
How hot did it get, how long did it run WHILE hot, did everything smoke when shut off, does it leak anywhere, is there a 'milkshake' type of sludge in the oil, is there oil in the coolant, does anything look hot or melted did any coolant lines rupture/disconnect, did any freeze plugs pop (does this thing have freeze plugs?), did you refill/flush the coolant and try to run it again, does it make any weird noises when running again (AFTER a refill), did/do any DTCs pop up, does it have any different driving characteristics while driving post-vs-prior...
Tons of info is missing here.
Old Apr 26, 2018 | 06:53 PM
Cee Jay's Avatar
Ya beat me, Sparky
Old Apr 26, 2018 | 06:58 PM
Originally Posted by Cee Jay
Ya beat me, Sparky
Like a rented Mule!
Old Apr 26, 2018 | 07:04 PM
Ranchero50's Avatar
Need way more info to make a relevant response...
Old Apr 26, 2018 | 07:49 PM
Mandrake's Avatar
Originally Posted by sparky fuze
Like a rented Mule!
Or a red coupe.
Old Apr 26, 2018 | 07:53 PM
Cee Jay's Avatar
Originally Posted by Mandrake
Or a red coupe.
..... I don't get it.....
Old Apr 26, 2018 | 10:31 PM
stahoo's Avatar
Was running 75 on the turnpike when steam came from under the hood and temp light came on. shut er down and had it towed. 50,000 miles. It will crank but wont start. coolant bottle was empty. took oil cap off, clean as a whistle. no milky look. No dip stick so cant see oil. Gonna drain oil this week end. If its a head gaskit or what?
Old Apr 26, 2018 | 11:06 PM
Mandrake's Avatar
Do a leakdown test to see if the HG is done.
Old Apr 26, 2018 | 11:20 PM
S-Typer's Avatar
Sounds spot on for a 2011 @ 50k to blow a water pump. The early pumps sucked. They will leak fast and drain all coolant. Hopefully you shut it off in time. Not sure if that explains the non-starting condition.
Keep us posted when you drain the oil.
Joe
Old Apr 27, 2018 | 07:07 AM
Ranchero50's Avatar
I would expect it to start once it cooled off unless the electronics got hosed with coolant. No obvious signs of leakage?
Keep track of how much oil you get out of it and what it looks like. 5.0's have a tendency to run low and eat themselves.
Old Apr 27, 2018 | 07:25 AM
10XKR's Avatar
Could it be that some code(s) is thrown that the computers will not let it fire up until the fault is corrected? Sort of a self preservation mode?
Dave
Old Apr 27, 2018 | 08:29 AM
shemp's Avatar
off topic but I haven't heard this before. ??
Old Apr 27, 2018 | 09:48 AM
Cee Jay's Avatar
For an oil condition (milky or not) pull off the oil filter. It is on top and super easy to get your hands on. Any milky substance would be evident right there.
And syntax........
"......... . shut er down and had it towed. 50,000 miles. ......." Damn, one hell of a Tow Charge.
Old Apr 27, 2018 | 10:30 AM
jagtoes's Avatar
Never heard this either. From what I have read JLR engines didn't even make the top 30 oil consumption cars. I believe BMW and Subaru lead the way.
Old Apr 27, 2018 | 01:08 PM
Ranchero50's Avatar
Been four or five threads in the X150 or F type subs since I bought mine that discussed it. Typically first post material and you seldom hear back from them.
Old Apr 27, 2018 | 01:20 PM
Cee Jay's Avatar
Yep, all three OP posts in this thread.
Ya know, it sort of is the job of this forum to help newbies with their car problems. Just because the OP doesn't want to maintain a 'relationship' with a forum doesn't necessarily mean that he doesn't need/like it.
We provide a service!
I'm also in the F150 forum (also by IB) and I have very few posts in there. There is a LOT of good info in that forum as well, but there is just SO MUCH OF IT. Some threads have 25,00 posts and comments. There are over 500,000 different threads, and that was before I got past Page One.
It would be nice to have the OP here post a resolution or close the thread out, but at least it gets the rest of us to use our brain-holes a bit.
