Overheating Issue Solved, I think.
Old Sep 26, 2023 | 05:23 PM
Sebring12Hr's Avatar
Default Overheating Issue Solved, I think.
My engine overheated and I did not realize it until I had driven at least a few miles I wish these cars had analog gauges!! A rather dim warning message had popped up in the center of the instrument cluster but I did not see it right away. What alerted me to a problem was that suddenly the A/C was blowing warm air. It was 95 degrees that day. So I was screwing around with the controls trying to resolve that. Thinking back, the same thing had happened randomly 4 or 5 times over the past few months. But then it would just start blowing cold again. What I now think is that the cold air shuts off automatically when the engine begins to overheat???
So I figured I likely warped a head or worse! Must be a thermostat or water pump. I changed the engine oil, drained the old coolant and refilled it and figured I'd see if it would start and run OK. Fired up perfectly. Took it on some short drives around the block and then progressively longer drives and found a coolant leak at a coupling in the rubber hose between the thermostat and overflow tank. I took this joint apart and the plastic coupling crumbled apart in my hands! I replaced it with an aluminum coupling. Been driving regularly for 2 weeks now in 90+ temps with no issues. I think I dodged a bullet.
My theory is that the deteriorated plastic coupling was partially blocking circulation of the coolant and/or leakage over time may have lowered the coolant level. I had water wetter in the system and maybe this helped save things.
Old Sep 26, 2023 | 05:33 PM
sov211's Avatar
You may not be quite out of the woods yet. The plastic thermostat housing tends to fatigue with time and heat/cooling cycles and pieces can break off internally, obstructing the functioning of the thermostat itself. If this has not been replaced, it probably should be because of age, if nothing else.
Old Oct 5, 2023 | 12:59 PM
sony2000's Avatar
sov211, can you post, or anyone, a picture of the thermostat housing that tends to fall apart. I already experienced the above coupling fail the first day of owning my Jag. A plumbers 3/8" copper tube, made a good replacement.
Old Oct 5, 2023 | 01:06 PM
sov211's Avatar
I no longer have my XK so I am unable to provide a photo of the thermostat housing. Perhaps someone else can oblige?
Old Oct 7, 2023 | 03:28 AM
guy's Avatar
guy
The diagram in the workshop manual…
Old Oct 7, 2023 | 01:46 PM
Sean W's Avatar
take a look here:
https://www.jaguarforums.com/forum/report.php?p=1731069
Old Oct 7, 2023 | 02:05 PM
NBCat's Avatar
Here is a listing and photo from SNG Barratt of the water outlet pipe, which contains the thermostat:
https://www.sngbarratt.com/English/#...20SYSTEM(12442)
Old Oct 7, 2023 | 04:15 PM
Sean W's Avatar
@NBCat would you recommend the aftermarket, have any experience with it or stay with OEM?
Old Oct 7, 2023 | 06:10 PM
NBCat's Avatar
I would stick with the OEM parts whenever possible, unless the vehicle is off the road due to the part(s) not being available.
SNG Barratt have quality parts, so I would feel comfortable using the *aftermarket part from them.
Old Oct 7, 2023 | 06:14 PM
NBCat's Avatar
One caveat to bear in mind when replacing the water outlet is being careful not to damage the heads of the Torx screws whilst trying to remove them.
The two rear Torx screws one the lower part of the section that joins the block can be difficult to access with the inlet manifold in situ.
Old Oct 7, 2023 | 08:28 PM
panthera999's Avatar
Identical thing happened to me as Sebring on this coolant reservoir line. Recommend removing the clips, replacing the junk "plastic(?)" coupling with a metal one, similar to below, and replacing the clips with new or hoseclamps. Extraordinarily poor materials selection. Coupler can be found in any Home Depot or plumbing supply house for a few $. A new hose is $80+ if I remember correctly
This is pretty much a guaranteed eventual failure where used. Definite PM item worth solving before you have a problem.
Mine fell apart when I moved it, so I got lucky. If it goes by itself under pressure, not sure how fast it'll blow out coolant. Dangerous failure.
J4GU4R
Oct 30, 2025 10:30 PM
Micah Bernard
XE ( X760 )
Jun 11, 2023 05:54 PM
hirev
Jan 11, 2019 06:49 PM
Torrid
Dec 1, 2015 12:20 AM
jag xj8
Oct 10, 2011 08:39 AM
