Pandora Spotify etc
Old Nov 11, 2024 | 11:13 PM
alanroberts50's Avatar
Default Pandora Spotify etc
Ok I’m a bit confused by the Bluetooth threads. I just connected my iPhone XR and the Bluetooth in the Jag no problem. So what s the simplest way to play music from the internet? I don’t want to install Apple car play just want to play music from Pandora Spotify accounts like my friends who have Toyotas!😳
Old Nov 12, 2024 | 03:04 AM
RichardS's Avatar
If the Bluetooth connection is enabled for music then all you have to do is connect the phone to the car, select Bluetooth (or BT) as the source on the car entertainment screen and then fire up your preferred music source on the phone (streaming over the internet or stored on the phone memory) and it will play through the car audio system.
However, be aware that some cars are only configured for phone use over Bluetooth but will not play music. I suspect that this is the case with your car or you would have already solved your problem. You might well be able to get around this limitation by using a cable with a suitable adapter but without a change in hardware, Bluetooth music will probably not be possible.
Richard
Old Nov 12, 2024 | 09:49 AM
kj07xk's Avatar
If you have the 30 pin iPod connector in your center console glove box, get a Bovee WMA1000 (you might need an adapter cable if you don’t already have one). Search this forum for “Bovee” for more information. You’ll find threads like this one:
Bovee
Old Nov 13, 2024 | 02:44 PM
Madness's Avatar
Or Inveray. Cheaper and just as good
Old Nov 14, 2024 | 03:42 AM
Not here in South Africa Amazon quotes $186 but it looks to be a nice solution
Old Nov 14, 2024 | 10:03 AM
Sean W's Avatar
I have a bovee I can let go for less than that LOL but have no idea what it would cost to ship. PM me if you're interested.
Chieftan
Aug 12, 2023 09:05 PM
Salieri
Jun 15, 2017 12:37 AM
yeldogt
Nov 8, 2016 11:05 AM
XXXAngelXXX
Sep 1, 2016 07:07 PM
Unk
Mar 6, 2015 03:49 PM
