Parking aid
Old Jun 11, 2017 | 05:59 PM
Don-T's Avatar
Default Parking aid
Boo, hiss... I found out yesterday the parking aid automatically turns itself "OFF" over 9 mph but doesn't automatically turn itself back on. Trashed my air dam, damn. I really hate those concrete parking space tire stops! Oh well, off to the paint shop tomorrow to get a rattle can of "Salsa Red". If I remember to manually turn the parking aid "ON", will it even see those air dam eaters?
Old Jun 11, 2017 | 06:16 PM
jagtoes's Avatar
Yes it will but you need to turn the front ones on as you now understand. It took me a month to learn how to judge . I also use a self trained trick. The front sensors turn on when you put it into reverse so every time I pull into a space I go in half way , put it into reverse and then go forward. Works for me
Old Jun 11, 2017 | 10:56 PM
Cee Jay's Avatar
Why not use the ON/OFF switch which is on the roof, above the inside rear-view mirror?
Old Jun 11, 2017 | 11:26 PM
Queen and Country's Avatar
I have a question too.
Does the front sensor detect things only 6inches tall, the stuff that is barely tall enough to catch the front lip.
Old Jun 12, 2017 | 05:40 AM
jagtoes's Avatar
I do that if/when I remember.
Old Jun 12, 2017 | 06:22 AM
Tango Nevada's Avatar
Does the automatic turning off, but not on again, for the front parking sensors also apply to my '07 X150 XK?
Old Jun 12, 2017 | 10:47 AM
mij86's Avatar
Think the rears turn on automatically but the fronts have to be switched on.. might be wrong as I've only been a Jag owner for 4 days
Old Jun 12, 2017 | 10:55 AM
shemp's Avatar
They all turn on when you put it in Reverse. If you want the system on when pulling into a spot or garage forward, you have to enable it with the button.
Q&C, Not sure what the sensitivity is but mine catches a curb or parking spot stop thing pretty accurately and they are probably less than or about 6"
Old Jun 12, 2017 | 10:58 AM
mij86's Avatar
Cheers shemp, have to remember Jagtoes little trick too
