Pass Side Mirror Points Up In Reverse
Old Apr 24, 2012 | 03:20 PM
Chaos236's Avatar
Default Pass Side Mirror Points Up In Reverse
Help?
When I go in reverse the passenger side mirror tilt up not down.
Old Apr 24, 2012 | 04:35 PM
CleverName's Avatar
Originally Posted by Chaos236
When I put the car in R
Any recent work done?
Vince
Old Apr 24, 2012 | 04:43 PM
Stuart S's Avatar
Help?
Try adjusting the dip position using the 4-way controller at the front of the driver's door armrest. That's the round knob in between the left and right mirror selector switches.
First, shift into reverse. After the mirror stops moving, adjust the dip position using the 4-way controller. Shift out of reverse, then into reverse and see if that fixed it. If not, I think it might be time for a trip to the dealer.
Let us know if you got it to work. Good Luck!
Old Apr 24, 2012 | 04:50 PM
TFlan's Avatar
This is too obvious but I'll mention it anyway. The passenger mirror can be adjusted to your preference with the car in R and it will remember that setting.
Perhaps someone else drove it?
Best,
Old Apr 24, 2012 | 05:08 PM
CleverName's Avatar
Best,
Forget that was programmable that way...
Bet your right on...
Vince
Old Jul 8, 2014 | 12:50 AM
hendercc's Avatar
Thanks to Stuart and Tflan for a solution in this two+ year old thread. I just got my 2010 back from the dealer for the 30K service (and a rear main seal leak that they found in the process, 2 days before my warranty expired). My passenger mirror was now tilting up instead of down when I put it in reverse. With my warranty just expired, I thought, "oh crap. No way!" I searched the forum, found this thread and was relieved that it was spot on. I changed my passenger mirror setting after I selected reverse, saved the setting and it's now back to proper behavior. Woo hoo!
Old Aug 31, 2016 | 01:11 PM
pk4144's Avatar
"too obvious but I'll mention it anyway."
Not possible.
I was about to bring mine in.
Love these threads on this site. I enter "side mirror tilts up" and BOOM. Problem solved.
Old Aug 31, 2016 | 06:51 PM
DGL's Avatar
DGL
I was going to suggest maybe you were driving down under...
Old Sep 1, 2016 | 08:24 AM
Chadly's Avatar
Thank you all! Mine has done this since the day I bought it 2.5 years ago and is now fixed. You guys rock!
Old Sep 1, 2016 | 02:09 PM
Fspider's Avatar
Thats the only niggle with my xk, the mirror does what it wants to. In reverse it adopts what ever position it likes, then in drive it adopts what ever position it likes. No amout of adjustment or programing works, so i am always using the adjuster during and after.
I just live with it.
FrickenJag
Jun 16, 2025 02:15 PM
bamforp
Aug 14, 2024 05:36 PM
Wolfy
May 28, 2024 08:06 AM
tberg
Sep 7, 2015 07:32 AM
