Playing music through your droid using Bluetooth
Old Aug 9, 2011 | 10:20 AM
dd823's Avatar
Default Playing music through your droid using Bluetooth
What is the best way to play music on the Droid through your car stereo?
Old Aug 15, 2011 | 09:44 PM
Dan's Avatar
Dan
The only way I can get it to work is through the RCA inputs which is installed as an option. The stereo doesn't support bluetooth audio. I run Pandora and all other music this way and it sounds fine. I tried the USB with the droid and it did not work. I also have a USB stick with MP3's loaded which works as well
Old Aug 16, 2011 | 07:00 AM
dd823's Avatar
Thanks for the info I think am will get the connection installed by the dealer.
Old Aug 22, 2011 | 04:47 AM
liquidsilverxk's Avatar
Dan,
Are you using the Jag connection with your phone?
With the connector I can run my iPhone quite easily i.e. the iPod runs easily.
When I try to run Pandora it starts and then yours off. It also says no volume control. Am I missing something? What type of phone are you using?
Old Aug 22, 2011 | 09:37 AM
dd823's Avatar
HTC Incredible I have not added anything to the car yet
Old Aug 23, 2011 | 08:47 PM
Dan's Avatar
Dan
Originally Posted by liquidsilverxk
Dan,
Yes I am using the Jag Connection. I have the Samsung Galaxy S phone connected via the RCA inputs so you can't control the phone in a way from the jag touch screen. I haven't tried an iphone with my setup.
Jagzzz
Aug 8, 2021 02:45 PM
DFW
Jul 27, 2020 02:44 PM
inactualis
Oct 2, 2015 11:13 AM
Msteiner
Audio/Visual Electronics
Sep 30, 2015 08:36 AM
