Polyurethane bushings
Old Feb 12, 2025 | 04:25 PM
badicedog's Avatar
Default Polyurethane bushings
Advice wanted on PolyUrethane bushings. As I replace worn out suspension parts, I want to upgrade to Polyurethane bushings. Any company/product you guys recommend?
Old Feb 12, 2025 | 04:47 PM
guy's Avatar
guy
@badicedog , many opinions on this topic.
(but if you wanted a ride like an old corvette, why not just buy a corvette, lol)
Old Feb 13, 2025 | 02:23 AM
neilr's Avatar
Some of the stock bushes allow a degree of twist, which rigid bushes don't, allowing the suspension to move in the intended arc. Whether polyurethane bushings are really an upgrade to the sophisticated bushes originally used is open to debate. Jaguar, especially in the days of Mike Cross, weree pretty good at suspension design so somewhat random changes can degrade the original good work done.
Old Feb 13, 2025 | 01:06 PM
clubairth1's Avatar
Community Influencer
Prothane is one supplier.
They have a good selection of urethane bushings for Jaguars.
Prothane Bushings
I have had problems with squeaking and creaking noises so have tended to stay with rubber or OEM bushings.
Especially on a quiet luxury car like a Jaguar.
Old Feb 15, 2025 | 11:28 AM
jahummer's Avatar
I use Powerflex and have never had any squeeks or noise or failure.
Old Feb 15, 2025 | 01:56 PM
David993S's Avatar
Polyurethane bushing are great for the track, but a bit stiff for the street. So if you track your car, go for it, but otherwise you may grow tired of the ride.
Just IMHO.
Cheers.
Old Feb 17, 2025 | 07:06 PM
badicedog's Avatar
thank you
Old Feb 26, 2025 | 10:54 PM
Jag First timer's Avatar
I was told by a mechanic the poly bushings wear out very quickly.
Old Feb 27, 2025 | 07:41 AM
wymjym's Avatar
Don't use that mechanic.
WJ
baws
Mar 3, 2023 09:15 AM
cdre
Jun 22, 2017 05:41 PM
Dr John
May 1, 2017 12:23 AM
