Pops and Crackles
Old Jul 25, 2015 | 02:13 PM
carealtor's Avatar
Default Pops and Crackles
How can I coerce some pops and crackles out of my base/stock 2012 XK?
Old Jul 25, 2015 | 02:17 PM
ralphwg's Avatar
Get the Mina exhaust system and you will have subtle pops and crackles when down shifting or "feathering" the accelerator That is what I have on my 12 XK vert. You will also get a deep throaty sound under heavy acceleration.
Old Jul 25, 2015 | 09:17 PM
tberg's Avatar
Trade it in for an F-type R!
Old Jul 27, 2015 | 10:43 AM
Rey's Avatar
Rey
Suggest the cheapest mod is to replace the central resonator with a shallow X pipe ala "F". Summit Racing sells them:
http://www.summitracing.com/parts/wlk-53716
The main muffler on the XK has an internal spring-loaded flap that opens up the exhaust at a certain gas level. My guess is that this is about 4,000 rpm or so with full throttle. I suppose one could cut the muffler open and replace the exhaust spring with something a with a bit lighter extension, but this gets pretty technical as spring longevity could become an issue.
You could also install a used (hopefully cheap) XKR muffler and modify its external valve operation.
Another active exhaust possibility is Dynomax VT mufflers. These are "active" mufflers with an internal spring-loaded valve. Their action is much more aggressive than the stock XK muffler. Also, they are cheap.
X308XJR
May 20, 2019 06:50 PM
bdboyle
Nov 6, 2015 02:07 PM
10 XF Premium
Oct 2, 2015 09:22 PM
Swagguar
Sep 30, 2015 01:34 PM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
